CV joint wear, taken apart, cleaned up and worn out... I guess |
malcolm2 |
Apr 7 2014, 09:32 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
A thank you goes out to Mike Blizzard for supplying me with 2 axles this past weekend. I have taken them apart and cleaned the 40 year old grease out of them. I have watched Van Svensen's video on youtube and he showed 1 ?spider? with the same problem. He just turned his around. The outer portion of these CVs shows some wear.
I would have thought the outer would have more wear. But maybe the wear comes from poor lubrication? I still have the 2nd axle's joints to clean up, but that will have to wait 'til Tuesday. The cage shows only a slight bit of shine where the balls sit. All the other goodies are cleaned and show not wear. Missing 2 schorr washers, so somone had been in here before me. My limited knowledge of this tells me that both of these joints are bad and to call Eric and get me some new CV joints. I can't imagine that there are any good used joints left, or parts for that matter. Anyone agree.... disagree? (IMG:style_emoticons/default/chowtime.gif) |
Mblizzard |
Apr 8 2014, 05:04 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I remember reading somewhere that you can either swap the CV joint sides or position so that the worn part is not load bearing. I think this only works when there are small wear marks. If someone can confirm what I think I remember that might be an easier solution.
Lo-Fi Version | Time is now: 15th May 2024 - 08:45 AM |
