CV joint wear, taken apart, cleaned up and worn out... I guess |
malcolm2 |
Apr 7 2014, 09:32 PM
A thank you goes out to Mike Blizzard for supplying me with 2 axles this past weekend. I have taken them apart and cleaned the 40 year old grease out of them. I have watched Van Svensen's video on youtube and he showed 1 ?spider? with the same problem. He just turned his around. The outer portion of these CVs shows some wear.
I would have thought the outer would have more wear. But maybe the wear comes from poor lubrication? I still have the 2nd axle's joints to clean up, but that will have to wait 'til Tuesday. The cage shows only a slight bit of shine where the balls sit. All the other goodies are cleaned and show not wear. Missing 2 schorr washers, so somone had been in here before me. My limited knowledge of this tells me that both of these joints are bad and to call Eric and get me some new CV joints. I can't imagine that there are any good used joints left, or parts for that matter. Anyone agree.... disagree? (IMG:style_emoticons/default/chowtime.gif) |
914_teener |
Apr 8 2014, 07:24 AM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
The inner race in the photo looks bad.....mine werent that bad and were making a lot of noise. I'd use those for wrist rocket ammo.
I would call up Chris Foley and get new ones since you are in there. |
malcolm2 |
Apr 20 2014, 09:18 AM
The inner race in the photo looks bad.....mine werent that bad and were making a lot of noise. I'd use those for wrist rocket ammo. I would call up Chris Foley and get new ones since you are in there. (IMG:style_emoticons/default/icon_bump.gif) UPDATE: Well with the help of the donor shaft and 2 Tangerine CV joints I have installed the half shaft and new CV joints on the passenger side and the CLUNK CLUNK CLUNK is gone. Happy days. (IMG:style_emoticons/default/piratenanner.gif) I cleaned up the axle that I pulled from my car, expecting to see damage. Both joints look 100% better than the donor, core axle I got from Blizzard pictured in post #1. 914_teener, you are saying that I could get the CLUNKING without visible bearing damage? Is the clunking grease related? Old grease, too little grease? In Dr 914's book he mentions DRY joints can clunk. And that a new axle will smooth out the ride, I can attest to that. My ride is smoother. I did notice that one joint had a much more liquidy grease. Maybe water got in or the mixture of previous greases did something. |
Lo-Fi Version | Time is now: 15th May 2024 - 11:11 AM |
