| dlindzey |
Apr 9 2014, 08:24 PM
repeat offender ![]() ![]() Group: Members Posts: 51 Joined: 8-April 14 From: texas Member No.: 17,226 Region Association: Southwest Region |
i am out looking for a 914 but don't know what to be on the look out for in terms of most likely spots to rust out or engine quirks to avoid. i know all the pitfalls of triumphs but don't know what to look out for in the 914 world
| scotty b |
Apr 9 2014, 08:35 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
front trunk, rear trunk, and everything inbetween (IMG:style_emoticons/default/unsure.gif)
seriously (IMG:style_emoticons/default/unsure.gif) The " hell hole " is the biggest thing to check. It is the area in the engine bay below the battery. They almost always rot out there, and once that is opened up the water/acid mix runs into the passengers longitudinal and start rotting from the inside out. I have seen quite a few cars that LOOKED fine from the outside of the long and suspension console, until the paint was stripped away. The first thing to walk away from is if the passengers door gap is tight, particularly if the door drags or won't open at all. This is a sure sign the chassis is folding up from rust. Check the cowl in front of the windshield where the rubber strips are. That gets to be an involved repair. Check the rear trunk pan, check the front trunk pan, pull the seats forward and remove the carpet from behind them and check the floor there from the top side AND the bottom side. If the floor tar is still intact on the inside you won't see jack shnit. Check the back firewall between the pass compartment and engine compartment. The sound deadening pads held water and rotted out that wall. Check for folds or ripples in the sheet metal around the wheel wells and forward of them. So yeah, check the front trunk, the rear trunk and everything in between (IMG:style_emoticons/default/mellow.gif) |
dlindzey what to look for when buying a 914 Apr 9 2014, 08:24 PM
brant I won't buy a 914 without pulling the rockers ... Apr 10 2014, 08:21 PM
Evil914 I would rather replace/rebuild EVERY part of the d... Apr 10 2014, 08:39 PM
sfrenck Look for someone on 914world to go with you and lo... Apr 10 2014, 08:42 PM
orthobiz
Look for someone on 914world to go with you and l... Apr 11 2014, 05:48 PM
steuspeed Find as clean a car as you can. A fixer will cost ... Apr 10 2014, 09:11 PM
Johny Blackstain :wttc:
Rust really can occur anywhere on the 914 ... Apr 10 2014, 09:32 PM
mburkhart http://www.pelicanparts.com/914/How_to_buy_a_914.h... Apr 11 2014, 04:42 PM
ChrisNPDrider Ummmm, just buy the first one you fall in love wit... Apr 11 2014, 07:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th July 2026 - 09:07 AM |
