Brake Rotors, track use only |
Jetsetsurfshop |
Apr 14 2014, 05:15 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Hey paddock people,
Need brake rotors that will last at least a season. Heres the stats on my brakes 1976 911 5-lug 19mm master Hawk pads dtc-70 (front and rear) Zimmerman drilled and rotors I'm getting tiny cracks around the drilled holes of the rotor. I'm sure the Hawk pads are to blame. Under normal driving conditions I bet these rotors will last a good while. AutoX and Sebring is killing them. So....any good rotor ideas? Stoptech and Centric are out there for my 911 set-up. Anyone got anything to say on these or any other advice? (IMG:style_emoticons/default/biggrin.gif) Shane |
brant |
Apr 14 2014, 06:14 PM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Cool carbon break pads.
Now called kfp. 6 years on my rotors so far with 2 drivers. You don't need drilled rotors. Power slotted if you if you want |
Jetsetsurfshop |
Apr 14 2014, 06:52 PM
Matt Romanowski |
Apr 14 2014, 06:55 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
All drilled rotors crack. It's not a problem until the cracks between holes connect or the cracks get to the edge of the rotor. Post up a picture of what you have.
tscrihfield |
Drive Fast and Take Chances Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None |
Cool carbon break pads. Now called kfp. 6 years on my rotors so far with 2 drivers. You don't need drilled rotors. Power slotted if you if you want (IMG:style_emoticons/default/agree.gif) The drilled rotors were created for asbestos outgassing. Since we no longer have that in our pads it is really unnecessary. The slotted rotors are good but, solid face vented rotors are as well. The problem with drilled rotors are that they are going to crack, it's just a matter of time. Never used the KFP pads but knowing how Brant uses his car I'd say he's good source for this type of info. |
Jetsetsurfshop |
Apr 15 2014, 06:56 AM
All drilled rotors crack. It's not a problem until the cracks between holes connect or the cracks get to the edge of the rotor. Post up a picture of what you have. Here's the rotors I just pulled off the car. I hope the photos work, posting from my phone. (IMG:style_emoticons/default/sad.gif) Attached thumbnail(s) |
Jetsetsurfshop |
Apr 15 2014, 06:58 AM
I guess it worked.
Here's a closer look. Shane Attached thumbnail(s) |
Jetsetsurfshop |
Apr 15 2014, 07:12 AM
Cool carbon break pads. Now called kfp. 6 years on my rotors so far with 2 drivers. You don't need drilled rotors. Power slotted if you if you want (IMG:style_emoticons/default/agree.gif) The drilled rotors were created for asbestos outgassing. Since we no longer have that in our pads it is really unnecessary. The slotted rotors are good but, solid face vented rotors are as well. The problem with drilled rotors are that they are going to crack, it's just a matter of time. Never used the KFP pads but knowing how Brant uses his car I'd say he's good source for this type of info. Didn't know that about drilled rotors. Good info. I just thought they were there to help with cooling. |
wobbletop |
Apr 15 2014, 09:27 AM
Member Group: Members Posts: 382 Joined: 8-December 06 From: Ontario, Canada Member No.: 7,335 Region Association: Canada |
Yours are definitely worn. Most drilled rotors will have some chamfering around the holes to reduce cracking. Yours either didn't have those, or it's worn past the chamfering. I'd stick with blank rotors, or if you want to get fancy, use J-hook rotors.
Hawk pads can be tougher on rotors than other pads. I've tried quite a few pads and currently am running PF01 pads. They have good initial bite and are easier on the rotors. They tend to squeal when cold though. |
Randal |
Apr 15 2014, 11:07 AM
Yours are definitely worn. Most drilled rotors will have some chamfering around the holes to reduce cracking. Yours either didn't have those, or it's worn past the chamfering. I'd stick with blank rotors, or if you want to get fancy, use J-hook rotors. Hawk pads can be tougher on rotors than other pads. I've tried quite a few pads and currently am running PF01 pads. They have good initial bite and are easier on the rotors. They tend to squeal when cold though. +1 on the chamfering. Without chamfering you end up with a hole with a 90 degree angle to the rotors which cuts pads; this is according to a big time professional mechanic and racer I know. We were going to cut the rotors on my son's MB compressor, but cutting the pads would eliminate the chamfer area. You'd end up with a 90 degree angle which cuts pads. Bought new rotors instead. |
Seabird |
Apr 15 2014, 02:44 PM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
Another way to tell its time for new rotors is the delta in thickness from new. I think total allowable wear is in the neighborhood of 2mm. I can see in the pictures there is a concave radius on the inside edge of the rotor face; I bet your past the 2mm's. You got your moneys worth out of these.
Paragon |
Apr 15 2014, 03:31 PM
Newbie Group: Members Posts: 49 Joined: 6-February 03 From: Corpus Christi, Texas Member No.: 255 Region Association: Southwest Region |
You can do Sebro Slotted Rotors for a little over $80 ea.
brant |
Apr 16 2014, 10:39 AM
Cool carbon break pads. Now called kfp. 6 years on my rotors so far with 2 drivers. You don't need drilled rotors. Power slotted if you if you want What rotors are you using too sir? Shane my fronts are 911 vented rotors from ATE with the eliptical slotting they were really only a few dollars more than standard replacements my rears are 914/6 non vented stock rotors I had a machinist create the power slotting in them I'm not really sure the slotting is even necessary or that beneficial the right pads make the most difference I played with KFP on a 944Turbo and the car was really too heavy for them the hawks were superior on that car... but most of the pads are created for the common street performance market cars... corvettes, 911s, 944's, mustangs.... cars that weigh 3000lbs so a lot of the pad compounds don't work on a 914, even if they are the best pad you can get for your heavy car. kind of like tires, its all about the compound operating range I am going to do some brake temp testing this spring on the track for my car but there are some sweet compounds out there for lighter cars the KFP may or may not be the best but it is definitely a good compound, and rotor friendly brant |
ChrisFoley |
Apr 16 2014, 10:56 AM
I am Tangerine Racing Group: Members Posts: 7,910 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I've been completely satisfied with KFP pads as long as I've been racing my 914.
That's why it's what we sell. |
jhadler |
Apr 16 2014, 01:14 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Drilled rotors are not necessary in almost any application these days. Especially for a car that sees daily driver use.
Even formula 1 cars don't cross drill the rotors. Granted, they're carbon rotors, and have forced internal venting. Now... If you're really into autox, and you're looking at reducing unsprung mass as much as ridiculously possible, you might consider something like this... But plan on replacing those rotors frequently. And yes, this picture is from a legitimate competition car that won multiple national championships. -Josh |
Randal |
Apr 16 2014, 03:56 PM
Drilled rotors are not necessary in almost any application these days. Especially for a car that sees daily driver use. Even formula 1 cars don't cross drill the rotors. Granted, they're carbon rotors, and have forced internal venting. Now... If you're really into autox, and you're looking at reducing unsprung mass as much as ridiculously possible, you might consider something like this... But plan on replacing those rotors frequently. And yes, this picture is from a legitimate competition car that won multiple national championships. -Josh Must have worn out some tooling drilling those 150 odd holes! |
Jetsetsurfshop |
Apr 16 2014, 04:26 PM
Drilled rotors are not necessary in almost any application these days. Especially for a car that sees daily driver use. Even formula 1 cars don't cross drill the rotors. Granted, they're carbon rotors, and have forced internal venting. Now... If you're really into autox, and you're looking at reducing unsprung mass as much as ridiculously possible, you might consider something like this... But plan on replacing those rotors frequently. And yes, this picture is from a legitimate competition car that won multiple national championships. -Josh Wow, impressive! |
Matt Romanowski |
Apr 16 2014, 06:33 PM
If those rotors are thick enough, they are fine. The cracks look ok in the photos.
Jetsetsurfshop |
Apr 16 2014, 08:07 PM
I already replaced the ones in the pictures with a new set of Zimmermans. Was thinking about my next set.
I've looked at the Sebros. What about Centric or Stoptech? Anyone try these? Shane |
ThePaintedMan |
Apr 16 2014, 08:39 PM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Lo-Fi Version | Time is now: 27th April 2024 - 06:19 PM |
