Improved shifting for side shifters, bolt on? Maybe., Experimenting tonight. |
Dr Evil |
Apr 14 2014, 10:14 PM
Send me your transmission! Group: Members Posts: 22,999 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I have had this though for a long time to try and remove as much slop as I can in the shifting system. The tail shifter is a bit trickier, but not impossible. I have a side shifter in my new 914 and so, while I build up a transmission for it to drive to Hershey this weekend (this will be the raffle transmission, BTW. Trial by fire!), I decided to see how simple it would be to remove some of the slop.
First, see how much of a gap there is between the shift selector comb and the rod. This is a huge amount so any bit that can be removed should be an improvement. Step one was to add material to the sides of the comb faces (Yes, Scotty, I welded). Then, I hand filed the faces and re-formed them to a specific profile. The metal that was added was hardened and a real bitch to file. I figured it was worth it. The end result was a much tighter fit. There are a few parameters that I will not go into that need to be respected to get this to work, but the preliminary results were nice on the bench. With the material added and profiled on the faces, the stick throw fore and aft to select gears decreases significantly. There is still refinement that needs to be done on the profile, but so far the preliminary results are encouraging. Next, I will build a jig so I can directly observe and adjust my profile. And I will also be able to see where I can add material to take up the slack that one feels when they are in gear and can wiggle the stick back and forth. Once I get this prototype done and tested, I can do this treatment to any side shift console on an exchange basis and it will be a quick bolt on improvement (I hope). (IMG:style_emoticons/default/happy11.gif) |
Eric_Shea |
Sep 7 2014, 11:56 AM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
My teener shifts notchy like a Ferrari. Biggest and best improvement over stock I've "ever" experienced in any 901/911/915 based system -- 914 or 911. Meaning, it actually shifts better than my direct rod 911.
Rennshift Level III Linkage Kit on a side shift console is the secret. What's the catch? James no longer makes them. (IMG:style_emoticons/default/sad.gif) Good news? Chris Foley stepped up and offers a similar system. (IMG:style_emoticons/default/thumb3d.gif) http://www.tangerineracing.com/transmission.htm ***Make sure you get the spherical firewall bushing as well (just to the right of the linkage kit on their page).*** I wanted to retain my hand throttle and a vintage look in the cockpit so I installed a simple Weltmesiter short shift console under the felt carpet with a stock shifter and knob on top. I always felt that the linkage below was a "huge" issue with the slop, even on a later side shifter. For me, this has been proven with this set-up. If you're unhappy with your shifting, I would suggest that the $4-500 you would spend on the Tangerine linkage kit will earn you dividends for years to come. If you're not limited with "vintage" looks and are racing/autocrossing your car regularly, the Rennshifter is an amazing console. By far the best on the market. I have a feeling we'll be installing one of Chris's linkage kits in Mike's car (that has the Rennshifter) soon. I'll report back. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:34 AM |
