The Hotter it gets, The more problems I have |
Bleyseng |
May 29 2003, 10:47 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
A 1.7L doesn't need a ballast resistor only the 73 2.0L.
If the car is running great cold and runs like crap warm I think its running rich. Check the plugs for a reading to see. Your MPS could be starting to leak due to cracks, as it warms up it goes richer. Put a vacuum gauge on to see if it holds a 15hg vacuum for 5 minutes. If it slowly leaks down its going, if it drops like a rock its toast. Geoff |
need4speed |
May 30 2003, 01:38 PM
Member Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 |
Wait, wouldn't it be leaner if it got hot?
ne14914 |
May 31 2003, 11:44 PM
Me N My914 Group: Members Posts: 94 Joined: 4-March 03 From: Los Angeles, Cali (Inland Empire) Member No.: 388 |
QUOTE(acox914 @ May 29 2003, 07:41 PM) hey NE14914, are you going to the pomona swap this sun? (IMG:style_emoticons/default/cool_shades.gif) QUOTE hey NE14914, are you going to the pomona swap this sun? (IMG:style_emoticons/default/cool_shades.gif) Yes Ill Be there - Hope you get this thread. I have a limesh Green Teener. Will be looking for you guys .... |
Bleyseng |
Jun 1 2003, 09:20 AM
If the MPS is starting to go the "loss" of vacuum is read to go richer.
High vacuum is 15hg which you have at idle, that vacuum pulls the diaphram against the idle stop. No vacuum is at Wot and that read as full rich. So loss of vacuum makes the MPS read richer... Car is cold when starting up and needs the mix to be richer then it get hot and the mix should be leaner. Geoff |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:20 PM |
