shifting |
shifting |
cpavlenko |
Apr 16 2014, 05:40 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
My 71 stocker has a new trans. It shifts nicely through all gear, note still breaking in, so it's tight. But what i notice is when setting at a light, and pushing clutch down and going into first it can be hard to get it right and sometimes I have to double clutch to get into first so I don' t get a grind. All new bushing down to the rear tail...is there a correct way to make adjusting under tunnel inspection panel. (IMG:style_emoticons/default/confused24.gif)
struckn |
Apr 16 2014, 05:57 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
My 71 stocker has a new trans. It shifts nicely through all gear, note still breaking in, so it's tight. But what i notice is when setting at a light, and pushing clutch down and going into first it can be hard to get it right and sometimes I have to double clutch to get into first so I don' t get a grind. All new bushing down to the rear tail...is there a correct way to make adjusting under tunnel inspection panel. (IMG:style_emoticons/default/confused24.gif) It's a 914 thing we all experience sometimes, been one of the more popular Post subjects. In short, the best solution is, when coming to a stop down shift to second and then to first, before stopping and keep the clutch peddle down until the light turns green. Also, the shift linkage bushings ware out and may need to be replaced. The one in the fire wall is the one that I think is potentially the major one to replace that helps the most. My 74 is a side shifter but your's may still be a rear shifter which is a little harder to get right with the adjustments for clean shifting I beleive. (IMG:style_emoticons/default/bye1.gif) |
Cap'n Krusty |
Apr 16 2014, 11:50 PM
My 71 stocker has a new trans. It shifts nicely through all gear, note still breaking in, so it's tight. But what i notice is when setting at a light, and pushing clutch down and going into first it can be hard to get it right and sometimes I have to double clutch to get into first so I don' t get a grind. All new bushing down to the rear tail...is there a correct way to make adjusting under tunnel inspection panel. (IMG:style_emoticons/default/confused24.gif) It's a 914 thing we all experience sometimes, been one of the more popular Post subjects. In short, the best solution is, when coming to a stop down shift to second and then to first, before stopping and keep the clutch peddle down until the light turns green. Also, the shift linkage bushings ware out and may need to be replaced. The one in the fire wall is the one that I think is potentially the major one to replace that helps the most. My 74 is a side shifter but your's may still be a rear shifter which is a little harder to get right with the adjustments for clean shifting I beleive. (IMG:style_emoticons/default/bye1.gif) Habitually sitting at a stop with the clutch pedal depressed causes premature and extensive wear on the crankshaft thrust bearing, as well as the case. If they're even available, oversize thrust bearings are probably expensive, and I've never seen one for a T4 engine. We usually just toss the case. The same holds true for most engines, and I've seen failures in Hondas, Mitsubishis, Hyundais, Toyotas, VW and Audi inline engines, and Chevys. Another specific problem in 914s is accelerated clutch cable wear and tube damage. The Cap'n |
Lo-Fi Version | Time is now: 16th May 2024 - 03:44 AM |
