First Engine Start Questions, First Engine Start |
Highland |
Apr 17 2014, 09:39 AM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I'm getting close (a relative term) to starting my motor for the first time. It is a stock 2.0 with Raby 9590 valve train. I know the easiest thing to do is put it in the car and start, but I have a running engine in the car now and I suspect I'll have to fix something after a try to start it. Here are my questions:
1) I have a spare transmission with starter. Can I start the engine without a clutch on the flywheel? 2) Can I start the engine without the alternator installed? 3) Without a charging system, can I use a car battery to power the coil and D-Jet for the break-in period (assuming I get that far) or will the battery die before then? 4) If I can't use a car battery to power the ignition and D-Jet, how big a power supply will I need? |
stugray |
May 29 2014, 12:41 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
It took me longer than I expected.
Just as I was about to start worrying the pressure started coming up and got to about 30-35 PSI. Once started, it got to 60 PSI or greater until warmed up. If you got oil to the filter, then the pump is primed and it should be making it to the pressure regulator. You did put the piston & spring in right? :-) After the regualtor, it has to fill the oil cooler before pressure begins to build |
Lo-Fi Version | Time is now: 19th May 2024 - 10:40 PM |
