First Engine Start Questions, First Engine Start |
Highland |
Apr 17 2014, 09:39 AM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I'm getting close (a relative term) to starting my motor for the first time. It is a stock 2.0 with Raby 9590 valve train. I know the easiest thing to do is put it in the car and start, but I have a running engine in the car now and I suspect I'll have to fix something after a try to start it. Here are my questions:
1) I have a spare transmission with starter. Can I start the engine without a clutch on the flywheel? 2) Can I start the engine without the alternator installed? 3) Without a charging system, can I use a car battery to power the coil and D-Jet for the break-in period (assuming I get that far) or will the battery die before then? 4) If I can't use a car battery to power the ignition and D-Jet, how big a power supply will I need? |
Highland |
May 29 2014, 05:07 PM
I tried cranking more this afternoon. No oil pressure. So I removed the oil pressure gage and could see oil through the gage opening. I then put the dummy light switch in place of the gage hoping to get a pressure indication there, but nothing.
I'm using a stock type 4 pump. The one off the engine was broken, so I replaced it with another stock pump replacing the o-ring. Since the oil filter has oil and I can see oil through the oil pressure port I assume oil is circulating through the system. The only thing I can think of is that the pump is worn and cannot maintain pressure or my starter isn't spinning fast enough. Should I look for another pump and swap pumps? |
Lo-Fi Version | Time is now: 19th May 2024 - 10:41 PM |
