First Engine Start Questions, First Engine Start |
Highland |
Apr 17 2014, 09:39 AM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I'm getting close (a relative term) to starting my motor for the first time. It is a stock 2.0 with Raby 9590 valve train. I know the easiest thing to do is put it in the car and start, but I have a running engine in the car now and I suspect I'll have to fix something after a try to start it. Here are my questions:
1) I have a spare transmission with starter. Can I start the engine without a clutch on the flywheel? 2) Can I start the engine without the alternator installed? 3) Without a charging system, can I use a car battery to power the coil and D-Jet for the break-in period (assuming I get that far) or will the battery die before then? 4) If I can't use a car battery to power the ignition and D-Jet, how big a power supply will I need? |
Highland |
May 29 2014, 05:07 PM
I tried cranking more this afternoon. No oil pressure. So I removed the oil pressure gage and could see oil through the gage opening. I then put the dummy light switch in place of the gage hoping to get a pressure indication there, but nothing.
I'm using a stock type 4 pump. The one off the engine was broken, so I replaced it with another stock pump replacing the o-ring. Since the oil filter has oil and I can see oil through the oil pressure port I assume oil is circulating through the system. The only thing I can think of is that the pump is worn and cannot maintain pressure or my starter isn't spinning fast enough. Should I look for another pump and swap pumps? |
bdstone914 |
May 29 2014, 05:24 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I tried cranking more this afternoon. No oil pressure. So I removed the oil pressure gage and could see oil through the gage opening. I then put the dummy light switch in place of the gage hoping to get a pressure indication there, but nothing. I'm using a stock type 4 pump. The one off the engine was broken, so I replaced it with another stock pump replacing the o-ring. Since the oil filter has oil and I can see oil through the oil pressure port I assume oil is circulating through the system. The only thing I can think of is that the pump is worn and cannot maintain pressure or my starter isn't spinning fast enough. Should I look for another pump and swap pumps? We had a fresh rebuild engine that we could not get the oil light to turn off when turned over by a 914 starter. Used a 911 starter and it went off in a few seconds. Remove the plugs and spin the engine. You may get it to turn fast enough to turn off the oil pressure light. The pump would have to be really worn to not produce oil pressure. |
Lo-Fi Version | Time is now: 20th May 2024 - 02:01 AM |
