Fried some wires, What to do next? |
john77 |
Apr 17 2014, 05:05 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Okay, before anyone else says it, yes, I'm an idiot. Now we have that out the way...
I've been trying to troubleshoot to figure out why my horn isn't working. Last night I thought I'd narrowed it down to the switch and then as I was looking at the wiring diagram my brain had a bright idea. I figured if I jumped a wire from 30 to 87 on the horn relay base it would bypass the need for the solenoid to be triggered thus bypassing the need for the switch, and if everything else in the circuit was working the horns should sound. So I just tried it and they didn't. (Was I wrong?) Then, and now I've stopped to think about it I have no idea why, I decided to take that wire out and instead jump it from 85 to 86 and... puff... a cloud of smoke wafts from under my dash and I quickly turn off the ignition. On closer inspection I've melted the brown wire (that haynes says should be brown/white) and the red/white wire that both go into the relay base. And I also noticed a brown wire attached to the ground by the fuse box has a blister in it too, although I'm not sure how those two things are connected? So, what did I do and what do I need to do next? And why didn't fuse 8 pop and save me from myself? Any advice much appreciated. Thanks John |
toolguy |
Apr 17 2014, 05:40 PM
Senior Member Group: Members Posts: 1,267 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
the wire going to the horn button has battery on it from the horn relay. . the horn pad in the steering wheel grounds that battery when pushed. . that operates the horn relay. . the relay passes battery to the actual horns. . grounding the brown/white horn wire in the steering column horn pad should operate the horn relay. . even is the horns didn't operate, you should have heard the relay on the fuse panel click
No clickie then the circuit from the horn pad to the relay is bad. . . if you hear the relay click, then the wiring from the relay to the horn is bad. . This is assuming no DAPO made wiring changes. .You might want to change the relay with a know good one first |
Lo-Fi Version | Time is now: 12th May 2024 - 08:44 AM |
