Fried some wires, What to do next? |
john77 |
Apr 17 2014, 05:05 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Okay, before anyone else says it, yes, I'm an idiot. Now we have that out the way...
I've been trying to troubleshoot to figure out why my horn isn't working. Last night I thought I'd narrowed it down to the switch and then as I was looking at the wiring diagram my brain had a bright idea. I figured if I jumped a wire from 30 to 87 on the horn relay base it would bypass the need for the solenoid to be triggered thus bypassing the need for the switch, and if everything else in the circuit was working the horns should sound. So I just tried it and they didn't. (Was I wrong?) Then, and now I've stopped to think about it I have no idea why, I decided to take that wire out and instead jump it from 85 to 86 and... puff... a cloud of smoke wafts from under my dash and I quickly turn off the ignition. On closer inspection I've melted the brown wire (that haynes says should be brown/white) and the red/white wire that both go into the relay base. And I also noticed a brown wire attached to the ground by the fuse box has a blister in it too, although I'm not sure how those two things are connected? So, what did I do and what do I need to do next? And why didn't fuse 8 pop and save me from myself? Any advice much appreciated. Thanks John |
john77 |
Apr 17 2014, 06:32 PM
Thanks guys.
Before I engaged my brain incorrectly and hooked 86 to 85 these are the things I knew that made me suspect the switch: 1. The horns are new, I've tested them across the battery and they work. 2. The relay works - I switched it out with fog relay and the fogs still worked. 3. The relay base was getting 11.5V at terminal 30 with the ignition off and 30 and 86 with the ignition switched to ACC. 4. When I press the horn I do not hear the relay click. I didn't check the hot wire at the horn, but from what you're saying it should read 11-12V even with the ignition off, right? I haven't tried grounding the brown/white horn wire into the switch, I'll give that a try once I've fixed the frazzled wiring. Which leads me back onto the frazzled wiring... Will the damage be localized around the relay or do I need to check the entire length of each of the wires - brown/white and red/white? And how the hell do you get into the rubber relay bases that hold the female terminals to check the wire connections? Is it even possible, mine seem to be a single piece of molded rubber. |
Lo-Fi Version | Time is now: 13th May 2024 - 12:29 AM |
