Fried some wires, What to do next? |
john77 |
Apr 17 2014, 05:05 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Okay, before anyone else says it, yes, I'm an idiot. Now we have that out the way...
I've been trying to troubleshoot to figure out why my horn isn't working. Last night I thought I'd narrowed it down to the switch and then as I was looking at the wiring diagram my brain had a bright idea. I figured if I jumped a wire from 30 to 87 on the horn relay base it would bypass the need for the solenoid to be triggered thus bypassing the need for the switch, and if everything else in the circuit was working the horns should sound. So I just tried it and they didn't. (Was I wrong?) Then, and now I've stopped to think about it I have no idea why, I decided to take that wire out and instead jump it from 85 to 86 and... puff... a cloud of smoke wafts from under my dash and I quickly turn off the ignition. On closer inspection I've melted the brown wire (that haynes says should be brown/white) and the red/white wire that both go into the relay base. And I also noticed a brown wire attached to the ground by the fuse box has a blister in it too, although I'm not sure how those two things are connected? So, what did I do and what do I need to do next? And why didn't fuse 8 pop and save me from myself? Any advice much appreciated. Thanks John |
Dave_Darling |
Apr 18 2014, 05:14 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Look on the other page of the diagram for a little number 14 with a red/white wire.
Basically, it carries switched power. It's probably coming from the ignition switch. The relay in question provides switched power to a bunch of things up in the dash, not just the fresh air blower. It's best to get the circuit fixed. --DD |
Lo-Fi Version | Time is now: 13th May 2024 - 10:26 AM |
