17" Trubo twist wheels on 914 with fender flares, need help on set up |
Confused |
Apr 18 2014, 03:30 PM
Newbie Group: Members Posts: 4 Joined: 14-May 13 From: Villa Hills, KY Member No.: 15,871 Region Association: None |
I wondered if anyone has tried to run 17" turbo twwist wheels on their 914. The tires that came on the wheels are 205/50/17 fronts, and 255/40/17 rears. Wanting to go less "chunky" on the size, I was advised to go to a 195/40 front, and a 245/35 rear. Also, it looks like I need approx. a 20mm spacer for the rear, and about 13.5mm front. Any help is appreciated. Confused.
bdstone914 |
Apr 18 2014, 09:18 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have a few sets of 21 mm spacers and some thicker ones. I think they are 1-1/4. Why not bolt up the wheels and see how they fit ?
It would give you a starting point. The studs required vary with the amount of spacer used. The lenght needed is 45 mm plus the spacer thickness. |
Lo-Fi Version | Time is now: 16th May 2024 - 09:23 PM |
