syncing Weber carbs |
offwatch |
Apr 19 2014, 05:40 PM
Newbie Group: Members Posts: 44 Joined: 4-December 13 From: Vancouver, WA Member No.: 16,725 Region Association: None |
Trying to sync the carbs, on the left side both throats have the same flow at idle but on the right side carb the front throat is higher then the back. How do I adjust so both front and back have the same air flow?
Dtjaden |
Apr 19 2014, 06:32 PM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
The air bleed screw. It's the one with the lock nut next to the idle mixture screw (I'm assuming IDF carbs).
offwatch |
Apr 19 2014, 06:55 PM
Yes IDF, Thanks.
Elliot Cannon |
Apr 19 2014, 10:15 PM
Good information here. http://www.redlineweber.com/
Kirmizi |
Apr 20 2014, 01:41 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Lo-Fi Version | Time is now: 26th April 2024 - 04:37 PM |
