Remotec Magnesium wheels, never seen these around before |
veltror |
Apr 20 2014, 10:38 AM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
Mike Bellis |
Apr 20 2014, 10:45 AM
Look kind of like BRM wheels. We don't get all the cool wheels on this side of the pond...
veekry9 |
Apr 20 2014, 02:04 PM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
Magnesium Alloy Forging,Race quality and strength, If you look closely you may discern what looks like push-out-pin marks on the face of the spokes,indeed that is what they are.The heavy pressures developed on the die made it necessary to remove the part from the anvil.Expensive process. Worth every euro,rare. Edit:03/21/15 Perhaps a series of photos of greater detail will determine the method used.Was any flash evident on the part? After some searching,a number on the order of 500 sets were produced,as a source in Aus mentioned. Removing the tire and testing for "ring-tone"when rapped is a sure method. As similar designs were for certain pressure cast,perhaps that set was machined in a secondary op. Pretty sure the test records are available to this day. Edit:04/10/15 A longtime racer here has informed me that the wheels,though of very high quality,were pressure cast.500 wheels,not sets. |
smarens |
Apr 20 2014, 06:39 PM
Member Group: Members Posts: 69 Joined: 15-March 14 From: Michigan Member No.: 17,121 Region Association: None |
I like the look of those (IMG:style_emoticons/default/smile.gif)
Chris H. |
Apr 20 2014, 07:49 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Yeah they also sort of look like an older style of Ronals although they normally came in smaller diameters like 13". Popular on BMW 2002s. Cool look.
lonewolfe |
Apr 20 2014, 07:53 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Not bad looking wheels. They look light!
veekry9 |
Mar 21 2015, 06:18 PM
These wheels are the Remotec diecast wheels of similar design. Note the flash on the top of the ribs,aluminum alloy. The magnesium wheel has thicker rib sections,and larger corner rads. |
veekry9 |
Mar 21 2015, 06:52 PM
Ronal,similar. Doh,same wheel posted above. |
lonewolfe |
Mar 21 2015, 06:57 PM
Nice looking wheels!
Lo-Fi Version | Time is now: 5th May 2024 - 06:03 AM |
