T.D.C |
T.D.C |
RonnieJ |
Apr 21 2014, 05:33 PM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
Looking at the fan on my 1.7 at the TDC area as you are looking left to right there are two 00's a red verticle mark and then an unpainted verticle mark....which of those are TDC...Thanks
stugray |
Apr 21 2014, 06:32 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Towards the rear of the engine, pop the engine tin metal tabs up over the edge of the case and push it back.
You can see the flywheel through a notch in the trans case. Through there you will see the TDC mark on the FW. I even use that mark to set the timing. It is much easier. |
barefoot |
Apr 23 2014, 07:14 AM
Senior Member Group: Members Posts: 1,270 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
yrs ago, I modified a spark plug by gutting it and welding in a rod extending about 1" beyond the threads. put in cyl #1 and rotate engine till piston touches, then rotate opposite direction till it touches again. Half way between is TDC, this only works with engine on stand with some kind of degree wheel or marks on flywheel where piston touched and flex rule to measure 1/2 between.
Lo-Fi Version | Time is now: 4th May 2024 - 04:04 AM |
