> T.D.C
RonnieJ
post Apr 21 2014, 05:33 PM
RonnieJ
Looking at the fan on my 1.7 at the TDC area as you are looking left to right there are two 00's a red verticle mark and then an unpainted verticle mark....which of those are TDC...Thanks
Replies(1 - 2)
stugray
post Apr 21 2014, 06:32 PM
Towards the rear of the engine, pop the engine tin metal tabs up over the edge of the case and push it back.
You can see the flywheel through a notch in the trans case.
Through there you will see the TDC mark on the FW.
I even use that mark to set the timing. It is much easier.
barefoot
post Apr 23 2014, 07:14 AM
yrs ago, I modified a spark plug by gutting it and welding in a rod extending about 1" beyond the threads. put in cyl #1 and rotate engine till piston touches, then rotate opposite direction till it touches again. Half way between is TDC, this only works with engine on stand with some kind of degree wheel or marks on flywheel where piston touched and flex rule to measure 1/2 between.
- Lo-Fi Version Time is now: 4th May 2024 - 02:26 AM
