BIG VALVE BIG PORT TYPE 4 BUS HEAD |
Type 4 Unleashed |
Jan 13 2005, 02:42 AM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
Type 4 Unleashed |
Jan 13 2005, 02:43 AM
(IMG:style_emoticons/default/WTF.gif) Exhaust side
Type 4 Unleashed |
Jan 13 2005, 02:51 AM
More of a streetable version (IMG:style_emoticons/default/WTF.gif)
Type 4 Unleashed |
Jan 13 2005, 02:52 AM
Exhaust (IMG:style_emoticons/default/WTF.gif)
spare time toys |
Jan 13 2005, 07:17 AM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
Is that the same head manufacture Jake is using in his head that he is showing in his head thread? I see both have the AMC cast into them. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Joe Ricard |
Jan 13 2005, 07:24 AM
Best aas I can recall the other casting is the square port design.
BTW whats the hole in the side of the exhaust port for? smog pump? |
ChrisFoley |
Jan 13 2005, 08:16 AM
I am Tangerine Racing Group: Members Posts: 7,927 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The only thing these heads and Jake's heads have in common is the AMC castings. Both use their square port bus heads as a starting point.
I don't see any value at all in using the heads shown here in a 914. There are no exhaust systems available to fit them for starters. I make stub pipes for my exhaust systems that mate up to the square ports - no need to make them round and create additional problems with pushrod tubes etc. ... and what's the deal with the "special mini side exhaust ports" It just looks like they went through the wall by over-enlarging the port to me... not a good thing! |
Jake Raby |
Jan 13 2005, 09:08 AM
Too much welding! All that welding has adverse effects on the integrity of the head, especially if it wasn't properly pre heated before the process.
They have filled all the passages that allow air to pass close by the exhaust ports! The exhaust ports are the hottest part of the head and the area that MUST attain airflow unless you want cracked ports. I seriously doubt those are good for anything other than a drag race engine- say good bye to a flat torque curve! Before jumping the gun to Titanium parts understand that they have negative effects including a valve job that will only last 1000 miles unless you use some new, very high tech coatings on the faces of the valves. This is VERY expensive! There is more to a 914 engine than just making power! Hang around a flow bench with a fellow like Len and see just what it takes to get an 80% head with the proper flow values at the most critical points of valve lift and see why headwork costs so much. All that weld work and they didn't relocate the plug- Must have never witnessed the same dyno results that Len and I have! |
Mark Henry |
Jan 13 2005, 12:20 PM
Much rather have Jakes/Len's heads.
see them here: http://www.914world.com/bbs2/index.php?act...=ST&f=2&t=23423 |
Bleyseng |
Jan 13 2005, 01:25 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Dyno? Flowbench? We don't need no stinkin Flowbench!
Its look cool thats all that matters! Geoff |
pete-stevers |
Jan 13 2005, 02:04 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
Now i know who Jake is... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
darn cool site/ great ideas for fours steve |
Type 4 Unleashed |
Jan 14 2005, 05:21 AM
Bleyseng |
Jan 14 2005, 08:43 AM
Thanks for sharing the pics of the heads, we are a bunch of doubting Thomas's when it comes to making real power with these. Giant ports aren't always the answer as port velocities slow waay down resulting in poor air/exhaust flow. Same holds true to huge valves. BTDT years ago. 8000 rpms is great but what about hp the rest of the rpm range?
Geoff |
ChrisFoley |
Jan 14 2005, 08:59 AM
I understand that all I would have to do is make special stub pipes for my header to fit, but as Geoff says the port velocities would be a big problem. There's just no need to go there IMO. My 1 3/4" header will easily support an engine with 225+ peak hp using smaller ports than the ones pictured. As far as dimpling the stub pipes goes, I already dimple the 1 5/8" square port stubs on one side. |
Type 4 Unleashed |
Jan 14 2005, 12:03 PM
Lo-Fi Version | Time is now: 20th May 2024 - 08:22 PM |
