Vacuum Advance ID, What distributors were fitted with these? |
toadman |
Apr 23 2014, 08:23 PM
Member Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
Came across a few vacuum advance units while searching for other parts tonight. I think these are 914 vacuum units but am not sure. The only number I see on them is the number on the actuator arm.
Each of these units has two nipples and an adjustment screw. One unit has 917 on the actuator arm. Other unit has 979 on the actuator arm. Can anyone tell me what distributors these go to? TIA |
Java2570 |
Apr 24 2014, 07:37 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
I have a spare 039 905 205A dizzy and it has the 979 # on the vacuum can. I don't have any documentation on those part numbers to back up that it's correct though. It does have the adjustment screw on the can. The vacuum can on my car now is from
a 039 905 205 -- no adjustment screw on that one. I'm not near my car now so I can't check but maybe someone else will chime in. |
Cap'n Krusty |
Apr 24 2014, 08:30 AM
I no longer have a copy of the old Bosch book that contains the list with the long numbers. Slits may have one. The digits you report are the last 3 digits of a 10 digit number (x xxx xxx xxx).
The Cap'n |
SLITS |
Apr 24 2014, 09:31 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
917 = '72 - '73 VW 412 1.7E according to Bosch ESI. Part number is 1 237 121 917 which is discontinued and replaced by 1 237 122 601. Other part number is Bosch 07109. This unit was also listed for a '73 914.
(1 237 121) 979 = does not come up in the literature For the 2.0L engines: '73 - '74 Distributor 0 231 174 009 = Part Number is 1 237 122 601 or 07140 '75 - '76 Distributor 0 231 174 011 = Part Number is 1 237 121 603 or 07128 That is all I have |
toadman |
Apr 24 2014, 06:13 PM
Thank you for your responses!
barefoot |
Apr 25 2014, 07:33 AM
Senior Member Group: Members Posts: 1,272 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Ditzy I acquired somewhere has VW P/N 022-905-205P
Bosch P/N 023-172-019 with JFUX4 Has vacuum advance & retard ports, advance limiting adjust & FI points Any info on it's origin ?? Barefoot |
Java2570 |
Apr 25 2014, 07:39 AM
Ditzy I acquired somewhere has VW P/N 022-905-205P Bosch P/N 023-172-019 with JFUX4 Has vacuum advance & retard ports, advance limiting adjust & FI points Any info on it's origin ?? Barefoot According to Brad Anders site: http://members.rennlist.com/pbanders/DJetParts.htm That # dizzy was a 1.7 70-73 MY unit and also indicates it was used on 73 Type 4's. SLITS may have a more concise listing in his documents. Jon |
SLITS |
Apr 25 2014, 09:19 AM
Bosch Number on your unit is 0 231 172 019 or 020
'72 - '73 VW 412 1.7E engine No other applications listed. |
Lo-Fi Version | Time is now: 7th May 2024 - 01:05 AM |
