car not fireing up, car had sat for a month , put in fresh gas an charged bat ,but no start |
thelogo |
Apr 28 2014, 09:17 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Photo is of line that starts at drivers end an swings around to right rear suspension ear
Area ,not positive its even fuel line , yall,tell me ? |
thelogo |
Apr 28 2014, 09:24 PM
Too bad I don't have one of those automotive inspection camera s on a flexi
Cord I could just look thru the hole in the He'll hole ( pictured below ) (IMG:style_emoticons/default/driving.gif) Attached thumbnail(s) |
Bob L. |
Apr 28 2014, 09:35 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
That's a hole in the battery tray. The hell hole is/would be below that.
Not sure, but the thing you're referring to looks like the emergency brake cable sheath. there should be one like it on the drivers side. Do they go to the rear calipers? |
thelogo |
Apr 28 2014, 09:58 PM
That's a hole in the battery tray. The hell hole is/would be below that. Not sure, but the thing you're referring to looks like the emergency brake cable sheath. there should be one like it on the drivers side. Do they go to the rear calipers? Crawled back under there , your correct ,but also the fuel line is right next to it as well as the filter , ( picture below ,its white box ) And the fuel line seems fine to it and exiting , but without being up on jackstands I cannot See nor acces.any higher up , or any higher then top of fuel filter . Fuel pump area correct me if I'm wrong Attached thumbnail(s) |
Bob L. |
Apr 28 2014, 11:08 PM
The pump should be on the firewall medial to/above the filter. Unless it has been moved up front or it's a '75-'76, in which case it started up front. I didn't see that you said what year it is.
TheCabinetmaker |
Apr 29 2014, 05:59 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Some folks don't read very well. You clearly stated that the gas is on the floor in front of the right rear tire. That doesn't equate to a leak under the tank.
Your last pic shows the very end of the pump and the white filter. Just because the hoses look ok doesn't mean anything. You must pressurize the system and visually inspect. Old hoses, especially the cloth covered one's, can seep thru the hose. I've also seen pump bodies crack and leak. Get it on jackstands or a lift and get under there while someone cranks the starter. Pull the plug wire from the coil while cranking to prevent a spark and don't put your face directly under the pump unless you like the taste of gas. Always keep an extinguisher handy when dealing with gas. |
Qarl |
Apr 29 2014, 07:19 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Some folks don't read very well. You clearly stated that the gas is on the floor in front of the right rear tire. That doesn't equate to a leak under the tank. Some folks looked at the photos showing a fuel spill in front of the car by the front tire/bumper |
TheCabinetmaker |
Apr 29 2014, 08:59 AM
Some folks don't read very well. You clearly stated that the gas is on the floor in front of the right rear tire. That doesn't equate to a leak under the tank. Some folks looked at the photos showing a fuel spill in front of the car by the front tire/bumper Yeah, saw that pic. You have to find the hidden text in his multiquotes. |
Apr 29 2014, 06:53 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You are close.
Jack the car up....high The wet line you have in your pic is the emergency brake cable....no fuel in that. There are two fuel lines that come out from the middle of the car, turn towards the passenger side along the rear lower firewall, then go to the fuel pump and filter in that corner. They are up high to keep them protected, so you will need to either jack up the car, or put it on ramps or a lift to repair this. |
thelogo |
Apr 30 2014, 10:27 PM
Great advice and thanks to all fellow members ,but jack stands and "lift up.really high to get under" Have me waving the white flag . Tow trucking it 7 miles to sandrail guru, aka lefty And have all fuel system gone thru . Sans ,f.I ( cause can't really be gone thru ) (IMG:style_emoticons/default/sawzall-smiley.gif) At least I will not.be piloting the Hindenburg (IMG:style_emoticons/default/welder.gif) Shout out to the cheap sob " (IMG:style_emoticons/default/beerchug.gif) Your are nothing but a moderate success in a moderate size pond" (IMG:style_emoticons/default/agree.gif) The great Ty Cobb |
Lo-Fi Version | Time is now: 31st May 2024 - 10:13 PM |
