> Shift coupler bushing options ?
pete000
post Apr 30 2014, 09:55 PM
Post #21
I am replacing my shift coupler bushings.
I purchased a white delrin set and they were way too sloppy and a poor fit. (IMG:style_emoticons/default/headbang.gif)
Next up is a set of urethane and they fit much tighter but the pin still floats around in the holes which appear to be oval shaped? Not sure if I would like that play due to the pin floating in the oval shaped holes. (IMG:style_emoticons/default/blink.gif)
I saw a set of solid brass bushings, these look interesting. (IMG:style_emoticons/default/shades.gif)
Has any one used them? (IMG:style_emoticons/default/idea.gif)
Are the pivot holes supposed to be oval shaped with slop around the pivot pin? (IMG:style_emoticons/default/idea.gif)
Any brand better than others? (IMG:style_emoticons/default/idea.gif)
There seems to be a lot of manufacturers out there and the prices go from $12 bucks to $40.00 for the brass ones. (IMG:style_emoticons/default/shades.gif)
pete000   Shift coupler bushing options ?   Apr 30 2014, 09:55 PM
Cap'n Krusty   The holes are oval per the factory design for 911s...   Apr 30 2014, 10:09 PM
02loftsmoor   Do you just drive that pin out to service the bush...   Apr 30 2014, 10:13 PM
pete000   Do you just drive that pin out to service the bus...   Apr 30 2014, 10:34 PM
SLITS   The ones currently supplied are for the 911. 914 ...   Apr 30 2014, 10:36 PM
pete000   The ones currently supplied are for the 911. 914...   Apr 30 2014, 10:39 PM
Dr Evil   Ya, I dropped $20 on the graphite ones as an ...   May 1 2014, 03:54 PM
Travis Neff   jwest has the bushings with the circular pin holes...   May 1 2014, 04:27 PM
CMONNETT   I used the brass ones in my car. Works great, imp...   May 1 2014, 04:44 PM
Dr Evil   Now that I have a 914 to drive and mess with, I am...   May 1 2014, 05:12 PM
TJB/914   Now that I have a 914 to drive and mess with, I a...   May 1 2014, 06:21 PM
pete000   I spent some time on the phone this morning with P...   May 1 2014, 06:40 PM
bdstone914   I spent some time on the phone this morning with ...   May 1 2014, 09:40 PM
JWest   The ones I use are a tight fit on the pin, once as...   May 1 2014, 07:57 PM
Qarl   So what is everyone's opinion on this stock co...   May 1 2014, 08:39 PM
Racer Chris   The universal joint I use to replace the coupler a...   May 2 2014, 06:41 AM
r_towle   The universal joint I use to replace the coupler ...   May 2 2014, 06:57 AM
Racer Chris   So your solution has a new coupler and rod, with ...   May 2 2014, 07:04 AM
Qarl   So your solution has a new coupler and rod, with...   May 2 2014, 07:06 AM
Racer Chris   CHris, Can you please talk a little about the st...   May 2 2014, 07:49 AM
r_towle   So your solution has a new coupler and rod, with...   May 2 2014, 07:16 AM
Racer Chris   :( You can buy sideshift boots new and used. Th...   May 2 2014, 07:25 AM
r_towle   :( You can buy sideshift boots new and used. T...   May 2 2014, 07:29 AM
Racer Chris   no additional work except removing the tail shift...   May 2 2014, 08:20 AM
r_towle   no additional work except removing the tail shif...   May 2 2014, 09:37 AM
gonzo54   I just ordered all of my shift bushings, Bronze Re...   May 16 2020, 10:21 AM
dr914@autoatlanta.com   the originals had a perfectly round hole and no sl...   May 16 2020, 10:37 AM
gonzo54   Thanks Dr 914, I want to get going on replacing my...   May 16 2020, 01:16 PM
roblav1   Although expensive, the Apex helicoptor joint is t...   May 16 2020, 03:32 PM
gonzo54   I'm not going to have a Apex helicopter joint ...   May 16 2020, 05:15 PM
roblav1   I figured that Rick. Info was for anyone else con...   May 16 2020, 05:17 PM
DRPHIL914   i got my brass bushings for the coupler on e-bay ...   May 16 2020, 07:53 PM
gonzo54   Thanks Dr Phil for the information and ebay contac...   May 16 2020, 09:03 PM
- Lo-Fi Version Time is now: 13th July 2025 - 08:40 PM
