Windshields, new, Source |
E-Man |
Jan 14 2005, 09:19 AM
Member Group: Members Posts: 158 Joined: 4-March 03 From: S. Windsor, CT Member No.: 390 |
I bought a new (tinted) windshield from this guy a few months ago for $175 and am happy with it. He imported a batch of them and sold them thru ebay. FYI -Mike
Richard Tankel -------------------- ProSource Glass International PO Box 996 Andover, MA 01810 Tel:877-345-2800 978-975-5400 Fax:978-975-5300 email:richardt@prosourceglassintl.com |
Root_Werks |
Jan 14 2005, 09:27 AM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I got a windsheild last year from a local guy in August for $225. He said he could still get another one as well. Good sign, there must be someone out there still making them.
That said, I have one that is just about perfect sitting on a parts car. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Flat VW |
Jan 14 2005, 10:02 AM
Illegal Soapbox Derby Racecar Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 |
Mine had one "clam":ph34r: in it (small) that one did not see at all while driving (obscured by the rear view mirror), a perfect place. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
About a month ago the windshield has developed an almost full circle crack around the mirror mount as if the mirror had been impacted (smacked) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) , perhaps causing the new crack (not involving the "clam":ph34r:). (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I need to replace it but I've spent some time in "glass shops" and seen a number of windshields changed and alot of them do not exactly "jump out of the windshield frame". (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) I gonna let someone else do this one I think. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
aircooledboy |
Jan 14 2005, 10:20 AM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
FYI bud, That was almost certainly caused by someone using the wrong kind of glue to attach the rear view mirror. Rear view mirror adhesive is a special kind of glue that happens to look very much like super glue. I used to see exactly the kind of crack you described pretty often when I was in the auto glass business. Invariably, it was due to people trying to glue on their rear view with super glue. The problem with "super glue" is that it binds too well to the glass, leaving no "give" for thermal expansion and contraction which results in a curved or circular break right around the mirror mount. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Another issue can be from the unusually broad base on many (most?) stock 914 mirrors. From the factory they were mounted with a thick adhesive that created a slightly flexible mounting point to allow for temperature changes. If you are putting on a broad based stock mirror with modern rear view mirror adhesive, it is important that you only put a small amount on the center and not to coat the entire base, since modern adhesive doesn't have nearly as much give as the factory stuff, and that can also cause a thermal stress crack because of the unusually large surface area of that style of base. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Flat VW |
Jan 14 2005, 11:22 AM
Thanks for reply, ACB. ---thread hi-jack terminated---- (IMG:http://www.914world.com/bbs2/html/emoticons/rocking nana.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif)
Lo-Fi Version | Time is now: 20th May 2024 - 05:04 PM |
