15x7 cookie cutter's on 914's |
madmax914 |
May 3 2014, 02:57 PM
Member Group: Members Posts: 204 Joined: 16-February 14 From: Salem, Oregon Member No.: 17,007 Region Association: Pacific Northwest |
Do 15x7 cookie cutter's fit 914's without spacers? Does anyone know the backpacking or offset?
brant |
May 3 2014, 03:44 PM
No spacers necessary. The are wide enough that 40 percent of them won't fit without pulling the fenders. You can only run about a 195 tire on them.
Been done many many times. 6 inch cookies are a guaranteed fit and allow a 205 tire |
May 3 2014, 04:25 PM
6 inch cookies are a guaranteed fit and allow a 205 tire On some 914s they will allow it. Most require the fender lips to be flattened or cut out, and many require a little bit of pull to fit the 205s. A few cars will require more than a little bit of pulling for 205s... --DD |
madmax914 |
May 3 2014, 05:57 PM
No spacers necessary. The are wide enough that 40 percent of them won't fit without pulling the fenders. You can only run about a 195 tire on them. Been done many many times. 6 inch cookies are a guaranteed fit and allow a 205 tire Do you know if they have the same backspace as a 5x130 alloy Fuchs wheel? |
brant |
May 3 2014, 06:37 PM
The same as a 7 inch fuch of the era
mskala |
May 3 2014, 08:01 PM
madmax914 |
May 4 2014, 08:53 AM
Thank you everyone for your help. 914world is great!
Lo-Fi Version | Time is now: 16th May 2024 - 01:12 AM |
