it begins, why is called "build" when you have to unbuild first? |
jacksun |
May 6 2014, 08:18 AM
Member Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
Hi,
well, it begins... winter is over and I have the whole garage to use.. history.... 73 1.7L....only know the last three owners... one brother purchased for 5 - 6 thousand years ago. he left it to his brother who did not drive it.. sat for "15 years in a pole barn" supposedly. the last brother auctioned off his possessions as he knew his days were less than he hoped for. he passed a week or two after the auction. the person I bought the car from said he paid $1800 at the auction. he had the car less than a week when his wife backed into the driver's fender. the truck sustained 22 hundred dollars in damage.. he supposedly bought the car to have a project with his son.. anyway he didn't want to deal with it anymore. I bought the car for $1500. I googled the name on the title and read the obituary notice. from that I was able to search and call a friend of his who told me the history of the brother's car. the actual price was $1700 at auction.. the extra $100 must have been the tow truck.. so far I have been working on the fender... I used to do furniture restoration for years in Portland Oregon. I like the process. I will drop the engine soon as I will need to have multiple tasks going as to use the wait time efficiently. this is my first time "attempting" body work.. youtube is great.. there are multiple things I plan to address with the metal. hell hole has to be addressed. longs look great from the outside, no sag, passenger door opens and closes fine with my weight sitting in the seat. 250lbs. interior is great, no cracks, a couple scuffs on the driver's door side of the seat "bolster?" has corduroy inserts. the back pad has some chew marks from mice on the bottom inner corner. the po had placed Irish Spring bars of soap in the cabin and trunks supposedly to keep the mice away. didn't work.. still.. car smells good.. the mice left chew marks in the soap. the bars are the original size... so maybe the "15yrs" is true. I have so many questions... and thank everyone in advance for the directions you provide me in the days to come... first question .............what guage metal should I use for the hell hole? is there a diagram for the body that gives all the gauges and locations? the front turn signal buckets that I have do not have the external bracket.. how do they attach to the car when you do have the bracket? as to the hell hole. I plan to cut away to good metal and then vacuum out as best I can... I read about using a magnet also. I have a cctv on a cable that I will use in the long to see what is what. I was planning on using a 4' tube attached to my spray gun and spraying "picklex" rust converter into the longs. wait for drying and then spraying "zero rust" using same tube/spray gun. after that cures I was planning on using "fluidfilm" sprayed using tube/gun. I am wondering if it would be a good idea to fab a plate that is removable (bolted) in the hell hole area so I can access it every year or so and spray more fluidflim???? thanks randal car at auction home car waiting for summer crinkled fender and work in progress |
ConeDodger |
May 6 2014, 09:57 AM
Apex killer! Group: Members Posts: 23,587 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
(IMG:style_emoticons/default/welcome.png) Get 'er done!
zambezi |
May 6 2014, 10:40 AM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
looks like a nice starting point. Welcome to the madness.
Krieger |
May 6 2014, 12:59 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
To answer your question it is necessary to "build" capital at all times so you can finish!
76-914 |
May 6 2014, 01:18 PM
Body is 20ga, structural is 18ga., usually. Eastwood makes a product that sprays the inside of the longs and/or tunnel, with 360 degree spray head and long leads. One can will do the longs but you'll need 2 cans if you do the tunnel as well. (IMG:style_emoticons/default/welcome.png)
Bartlett 914 |
May 6 2014, 01:52 PM
Nice looking car. It is good to folks in the midwest. How about some pictures of the Hell hole?
bulitt |
May 6 2014, 02:56 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
I am wondering if it would be a good idea to fab a plate that is removable (bolted) in the hell hole area so I can access it every year or so and spray more fluidflim???? Install a soaker hose in the longs, then you can pump it in by the gallon (IMG:style_emoticons/default/lol-2.gif) |
jacksun |
May 6 2014, 03:46 PM
jacksun |
May 6 2014, 03:49 PM
Body is 20ga, structural is 18ga., usually. Eastwood makes a product that sprays the inside of the longs and/or tunnel, with 360 degree spray head and long leads. One can will do the longs but you'll need 2 cans if you do the tunnel as well. (IMG:style_emoticons/default/welcome.png) thank you for the info... the spray gun with tube has a brass insert in the tip which disperses the material in a 360 also. it was a kit from a place in ma. thanks again randal |
jacksun |
May 6 2014, 03:52 PM
I am wondering if it would be a good idea to fab a plate that is removable (bolted) in the hell hole area so I can access it every year or so and spray more fluidflim???? Install a soaker hose in the longs, then you can pump it in by the gallon (IMG:style_emoticons/default/lol-2.gif) question is?? will doing as you suggested affect my gas mileage? (IMG:style_emoticons/default/confused24.gif) |
ruby914 |
May 6 2014, 05:06 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
Lo-Fi Version | Time is now: 16th May 2024 - 06:48 PM |
