| Mblizzard |
May 18 2014, 07:51 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Can you turn the WOT stop? On a MPS the first thing I do is remove the epoxy and clean the threads so I can unscrew it. Then I run it without the WOT until the adjustment is correct for part load. Then I install the WOT and set it's adjustment... Finally I epoxy it so it's not going to move just like oem. I don't like the drill a hole in it method.... This one was drilled but I am making the adjustments as you noted. |
Lo-Fi Version | Time is now: 10th June 2026 - 06:21 PM |
