2 Pages V < 1 2
> 2.0 Dizzy Question, Maybe I am just an Idiot
Cap'n Krusty
post May 13 2014, 07:44 PM
Post #21
Cap'n Krusty
QUOTE(r_towle @ May 13 2014, 05:42 PM) *
QUOTE(Cap'n Krusty @ May 13 2014, 11:16 AM) *
Time for me to check in. The diameter of the retard port on the TB and the one on the vacuum can are larger than the advance port and advance connection on the vac can. That in itself should make it clear which line goes where. With the throttle plate closed, there is significant vacuum on the retard port. If there's an advance port, there will be NO vacuum present at the smaller (advance) port on the TB with the throttle plate fully closed. If the hoses are connected properly (how can they NOT be, given the difference in port AND hose sizes?), the idle speed will be pulled down with the throttle plate closed, and it will rise significantly as the throttle is opened (as retard vacuum goes away). As the advance port vacuum gets stronger, the advance side of the can moves the plate and cause the timing to advance. There are NO variables here other than the strength of the vacuum signal and the freedom of the plate to move. None. It doesn't matter whether or not you unplug the retard hose when setting the timing at full advance, because it has no vacuum once the throttle is opened. Good habit to do so, though. As 914 TBs have no throttle stop adjustment for closed throttle, the plate should always be fully closed when at rest. If the cable is too tight, or the closed position has been artificially altered, that needs to be addressed. If the retard hose is attached to the advance port on the can, the idle speed will be way too high and the timing advance will only reflect the operation of the mechanical advance mechanism. Any questions?
The Cap'n
Just one question.
How many coats of plasti dip should I use on my magnesium transmission?
One leg is both the same. Everybody knows THAT ............................ Is this some kinda trick question?
The Cap'n
2 Pages V < 1 2
- Lo-Fi Version Time is now: 27th September 2026 - 05:29 PM
