> Stove top annealing, Who's done it?
bandjoey
post May 19 2014, 07:43 PM
bandjoey
Installing the exhaust tomorrow. I don't have a torch but I do Have a glass top stove. If you did the gasket ring annealing on your stove ok let me know. I don't want the copper gasket to damage the glass top. Thanks.
Elliot Cannon
post May 19 2014, 07:46 PM
Group: Retired Members
I'm not sure if you can do it on a glass top. I have a gas stove and it worked fine. I would go to Lowes, Home Depot etc. and buy a cheap propane torch.
dangrouche
post May 19 2014, 08:58 PM
dangrouche
you a Texan? hopefully you have a propane barbeque
Woody
post May 20 2014, 06:23 AM
Sandbox Rabblerouser and head toilet scrubber
QUOTE(dangrouche @ May 19 2014, 09:58 PM) *
No such thing as a propane bbq. Maybe a propane grill but not a bbq. pfft, californians. (IMG:style_emoticons/default/dry.gif)
post May 20 2014, 06:28 AM
(IMG:style_emoticons/default/agree.gif) We call those gas grilles. Perhaps the quickest way to tell if your neighbor is an implant. (IMG:style_emoticons/default/dry.gif)
ThePaintedMan
post May 20 2014, 07:37 AM
Yup, five minutes on a propane grill works just fine. Go bug your neighbor if you don't have one. (IMG:style_emoticons/default/beerchug.gif)
Elliot Cannon
post May 20 2014, 10:04 AM
I thought, in Texas, they still burned cow dung to cook on. Am I wrong? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/happy11.gif)
flash914
post May 20 2014, 10:41 AM
NOT ON GLASS TOP STOVE. It will put a whole in the top, Someone I knew did not center a pan on the top and the missing part opened up a crater. Gordon
Woody
QUOTE(Elliot Cannon @ May 20 2014, 11:04 AM) *
(IMG:style_emoticons/default/dry.gif) oak, mesquite, pecan, and hickory are what I use.
Moneypit
post May 20 2014, 12:17 PM
QUOTE(Woody @ May 20 2014, 11:41 AM) *
Welder friend is hardcore into BBQ, welds up his own pits from 55 gallon drums. He uses Gas for some stuff like Pork loin, and his pit obviously for brisket and sausage, and for smoking.
On topic, I have a dumb question. This is the second time I saw mention of anealing these copper gaskets for the heads/headers. What does the anealing do any why is it done?
worn
post May 20 2014, 12:36 PM
QUOTE(bandjoey @ May 19 2014, 05:43 PM) *
To anneal metals like copper or silver or gold one gets the metal red hot and then immediately quenches it into cold water. The quenching is important. If you want to you can build a small fire in the yard - I think you might see some scarring with the stove. The temp you are looking for is a dull but clearly visible red. Cherry red is a warning sign about melting. I think you are in the 1200 degree range, but I go by eye.
The quenching is VERY important. I know it sounds wrong to those of us working with steel, but air cooling is the way silver and gold workers actually harden the metal!
This started as a single sheet of silver and two stones. So I know my non-ferrous. Sorry it came out so huge.
And for the Capn - "Ah squiddy I had nothin against ye! I just heard there was gold in yer belly".
worn
post May 20 2014, 12:39 PM
QUOTE(Moneypit @ May 20 2014, 10:17 AM) *
The soft copper deforms to seal. In my experience they are fairly soft out of the package. But annealing makes sure. As long as you don't let them cool too slowly.
bandjoey
post May 20 2014, 11:27 PM
bandjoey
Ok. Broke down and got a propane torch. Makes for easy work and now I've got a fire starter for July 4 fireworks too!
- Lo-Fi Version Time is now: 9th September 2026 - 10:07 PM
