FS: FAT 2.6 Ltr Twin Plug w/ 2 stage dry sump Sold! |
sixforme |
May 20 2014, 05:40 PM
916 / 914-6 enthusiast Group: Members Posts: 10 Joined: 11-February 05 From: Kingman, Az Member No.: 3,587 Region Association: Southwest Region |
2.6 Liter disassembled, unsplit case, freshly remachined twin plug heads, new exhaust valves, guides and seats, J&E pistons, Autocraft 2 stage dry sump. These are $15,000 + engines from FAT and RAT. Rabys SS 2270 engine, quoted on his website, is $15,250 + a $1500 core, is $16,750! This is a much larger, twin plug, and dry sumped 2.6. !!! I am asking $3,500 IN "as is" condition. I have over $1,000 invested in work and new parts. If desired, FAT will recondition, dyno and certify this engine for approx $2,000.00, I am 325 miles from there and can deliver the engine in a matter of 4.5 hrs driving time. And because I am moving the car south from Seattle I can (possibly) deliver the engine for free on the west coast. :-) FAT degreed crank pulley Autocraft 2 stage dry sump oil pump Six high pressure hoses for pump and sump Unknown manufacturer mini oil screen/sump Canton CM 6 inch canister anodized fuel filter with bracket Sachs PP and disc, both new JE 103 mm w/230 forge mark. Lands cleaned, and reliefs cc'd to 2cc's, pin bores honed. Cyl's deglazed, have slightest ring ridge, hardly felt by touch. Modified Nissan 720 dual plug distibutor Finned cast aluminum valve covers All engine tin (highly modified to suit the Porsche shroud) SEV Marchal alternator p/n 712 330 02 / 70 amp 14v 11 blade 911 Porsche fan and 901 106 101 5r housing Late 2.0 heads (casting 039.101.371.A) oversize valves 48mm intakes swirled, 38mm sodium filled exhaust, 59 cc chambers 2 exhaust manifolds unknown manufacture or brand there is no serial number on the case see first picture in front of oil breather tower must be replacement case, smooth not ground off..... standard parts with engine starter single mount oil filter standard type 4 oil cooler Bore is 103mm Stroke is 78mm = 2599 cc = 2.6 liter the engine has been balanced as evidence of lightening is apparent on the rods and rod bolts. I believe the ports have been matched on the intakes. (in seattle) Not shown but available (in seperate storage unit in seattle in car) Weber 45 carbs manifolds and linkage twin bosch coils on bracket possible new rocker arm feet (Porsche 911) Notice The oil system is no longer avail as a package with this engine, they were not built together, the oil system was built for a six that was also in the car. The oil system is listed in another ad. Attached thumbnail(s) Attached image(s) |
sixforme |
Jul 28 2014, 12:43 PM
Bump for new price $3500 or make an offer
Lo-Fi Version | Time is now: 17th May 2024 - 08:45 AM |
