Throttle Cable Replacement, where the heck? |
jandro62 |
Jan 16 2005, 03:42 PM
Member Group: Members Posts: 104 Joined: 4-June 04 From: Texas Member No.: 2,156 |
I need to replace the trottle cable. How does this thing route from the engine compartment to the gas pedal? My Haynes manual is lacking any real information besides how to remove the pedal board.
Thanks, Alex |
McMark |
Jan 16 2005, 04:23 PM
To Remove The Pedal Board:
1. Remove the screw to the left of the clutch pedal. Remove the screw to the right of the gas pedal. 2. Pull the gas pedal towards the rear of the car until it pops off the linkage. Don't be shy, just pull. 3. Push the clutch pedal toward the front of the car and maneuver the pedal board over the clutch pedal. 4. Maneuver the pedal board over the brake pedal. This is hard the first few times you do it. |
jandro62 |
Jan 16 2005, 05:06 PM
Is there a good way to grab the cable to unscrew it from the pedal cluster? Is it like a tiny 4 mm wrench size?
rhodyguy |
Jan 16 2005, 07:42 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
did you remove the access cover on the front of the tunnel? fig 4.9 p.71. there's a little clevis(?) clip you have to pop off then the end of the piece that screws on the front cable should pop off.
kevin |
Lo-Fi Version | Time is now: 4th May 2024 - 02:27 PM |
