Worried about high oil temps?, and/or low oil pressure? |
boxsterfan |
Jun 8 2014, 09:53 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
How'd it go? |
Jetsetsurfshop |
Jun 12 2014, 09:42 AM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
How'd it go? Check this link from the paddock. Seabird had oil pressure issues before getting to test it out properly. http://www.914world.com/bbs2/index.php?showtopic=236133 |
BritCarJim |
Jun 12 2014, 09:24 PM
Member Group: Members Posts: 98 Joined: 22-January 12 From: Sevierville, TN Member No.: 14,043 Region Association: South East States |
hmm. sign me up too if it works out...
ChrisFoley |
Jun 23 2014, 10:07 AM
I am Tangerine Racing Group: Members Posts: 7,910 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I talked with Seabird on the phone this morning.
He was at the track again last weekend. The oil pressure problem related to new Accusump installation was cured. His data indicated that oil pressures and temps stayed within the desired parameters through two on-track sessions on a hot Florida day. I'm starting production of the pressure relief assemblies this week. Price is $74.95, delivered. They won't be on the website right away but I've provided a shopping cart button in my Whats New at Tangerine Racing Products thread in the Member Vendor forum. |
Mikey914 |
Jun 23 2014, 10:23 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Just ordered, I have 2 cars that can benefit form this.
Thanks |
Java2570 |
Jun 23 2014, 10:30 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Chris - I just ordered one! Thanks!! Jon
ww914 |
Jun 23 2014, 10:51 AM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
I talked with Seabird on the phone this morning. He was at the track again last weekend. The oil pressure problem related to new Accusump installation was cured. His data indicated that oil pressures and temps stayed within the desired parameters through two on-track sessions on a hot Florida day. I'm starting production of the pressure relief assemblies this week. Price is $74.95, delivered. They won't be on the website right away but I've provided a shopping cart button in my Whats New at Tangerine Racing Products thread in the Member Vendor forum. What are the "desired parameters"? |
stugray |
Jun 23 2014, 11:16 AM
Chris,
Does this completely eliminate the high pressure bypass for the oil cooler, or just require high(er) pressure before bypass? I have witnessed one blown oil cooler at the track due to low temps and too high of revs too soon after startup. |
ChrisFoley |
Jun 23 2014, 11:31 AM
Chris, Does this completely eliminate the high pressure bypass for the oil cooler, or just require high(er) pressure before bypass? I have witnessed one blown oil cooler at the track due to low temps and too high of revs too soon after startup. Stu, The stock relief circuit doesn't ever prevent full pressure to the cooler. It simply allows oil to take a shorter path when the pressure is high. My assembly completely eliminates the cooler bypass, and increases the pressure where excess oil is bypassed directly to the sump. |
lonewolfe |
Jun 23 2014, 01:17 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Chris! Thanks for the tip for removing the 12 pt socket from the side of the case with a 3/8" extension! That worked perfectly. Now, speaking of that valve, will it still be needed with this new modification?
Mblizzard |
Jun 23 2014, 01:24 PM
Chris,
I am running an external oil coller with a sandwhich plate oil filter adaptor. Will this result in more oil taking the external oil cooler pathway? |
ChrisFoley |
Jun 23 2014, 01:56 PM
Chris! Thanks for the tip for removing the 12 pt socket from the side of the case with a 3/8" extension! That worked perfectly. Now, speaking of that valve, will it still be needed with this new modification? I've been running my race engines with the secondary relief blocked off completely. Since many engines were produced without it, I tend to think it isn't really necessary. |
ChrisFoley |
Jun 23 2014, 02:07 PM
monkeyboy |
Jun 23 2014, 03:04 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Would this be a beneficial add to a stock motor internally?
ChrisFoley |
Jun 23 2014, 03:15 PM
jim_hoyland |
Jun 23 2014, 06:02 PM
Get that VIN ? Group: Members Posts: 9,262 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
VaccaRabite |
Jun 23 2014, 06:52 PM
En Garde! Group: Admin Posts: 13,426 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Ordered one.
I think my car has (or has had) just about one of everything Chris makes except the exhaust. Zach |
Mblizzard |
Jun 23 2014, 07:13 PM
jim_hoyland |
Jun 23 2014, 07:26 PM
(IMG:style_emoticons/default/smile.gif) found the link and submitted order.
HarveyH |
Jun 24 2014, 12:23 PM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
Showing my ignorance here, I try and not spend a lot of time under the car:
Can the install be done with the engine in the car? From pictures I've found the valve seems to be to the right of, and pretty much even with the lower edge of the oil pump. Is there room to swing a ratchet wrench and remove/install the mechanism without fouling the bodywork or something? Thanks, Harvey |
Lo-Fi Version | Time is now: 26th April 2024 - 10:27 AM |
