Worried about high oil temps?, and/or low oil pressure? |
CMONNETT |
Jun 24 2014, 12:58 PM
Member Group: Members Posts: 150 Joined: 27-September 07 From: Cibolo, TX Member No.: 8,162 Region Association: Southwest Region |
Just ordered mine, thanks again for the great products Chris.
ChrisFoley |
Jun 24 2014, 01:46 PM
I am Tangerine Racing Group: Members Posts: 7,923 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Showing my ignorance here, I try and not spend a lot of time under the car: Can the install be done with the engine in the car? From pictures I've found the valve seems to be to the right of, and pretty much even with the lower edge of the oil pump. Is there room to swing a ratchet wrench and remove/install the mechanism without fouling the bodywork or something? Thanks, Harvey Its an easy install with the car on jackstands - as long as you can get a big-ass flat-blade screwdriver on the cover. Probably takes 15 minutes, including jacking up the car. I'll be photographing an install later this week. |
HarveyH |
Jun 24 2014, 03:02 PM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
Thanks! Order placed.
I don't know about the 15 minutes though.... (IMG:style_emoticons/default/slits.gif) |
ChrisFoley |
Jun 24 2014, 07:06 PM
I guess if you haven't dusted off the jackstands in a while it could take some time. (IMG:style_emoticons/default/biggrin.gif)
hedfurst |
Jun 25 2014, 12:36 PM
Member Group: Members Posts: 99 Joined: 9-March 03 From: S. Mississippi Member No.: 406 |
Excellent!
ChrisFoley |
Jun 25 2014, 01:16 PM
craig downs |
Jun 25 2014, 07:42 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Just ordered mine. (IMG:style_emoticons/default/smile.gif)
boxsterfan |
Jun 27 2014, 08:17 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
I'm looking forward to people's results! Great innovation!!
lonewolfe |
Jun 28 2014, 05:36 AM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
I just placed an order for one! Can't wait to get the motor all together and put it to the test. I sure I'll be happy with the results!
HarveyH |
Jun 30 2014, 12:37 PM
Received today, included instructions seem very clear. Thanks.
Looking at the parts breakdown it appears there is a copper crush washer on the cover screw. I would think this is something that should be replaced when reseating the cover. Just go to the local FLAPS and match up a new one or ????? Thanks again, Harvey |
ChrisFoley |
Jun 30 2014, 12:55 PM
Received today, included instructions seem very clear. Thanks. Looking at the parts breakdown it appears there is a copper crush washer on the cover screw. I would think this is something that should be replaced when reseating the cover. Just go to the local FLAPS and match up a new one or ????? Thanks again, Harvey Most of the crush washers are aluminum. We re-use them several times without encountering leakage problems. You may not find one that fits at your FLAPS. I think the first 3 were shipped before I had the instructions ready. Anyone who didn't get them, just email me and I'll send electronically. |
VaccaRabite |
Jun 30 2014, 04:23 PM
En Garde! Group: Admin Posts: 13,441 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Mine showed up today.
:-) Zach |
Krieger |
Jul 27 2014, 12:44 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I have been wondering how this worked for you guys?
majkos |
Jul 27 2014, 04:20 PM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
wellllllllllllllll
I've been dying to get out and drive after I installed it, EASIEST INSTALL EV, ER!! I need to get tires on "Beauty" to test, I have having problems when after ? 30-45 minutes? temp. would race up to 260-270-280- no prob. (IMG:style_emoticons/default/WTF.gif) ?? I've been pondering the problem for the last few years, Why? I'm confident, Chris got it! (IMG:style_emoticons/default/aktion035.gif) |
MrHyde |
Jul 28 2014, 10:10 AM
Senior Member Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None |
Installed mine 2 weekends ago now.. immediately the hot oil pressure drop was fixed. Oil is running cooler too. Took me about half an hour to put in.. Not rushing and having a beverage while working away. I re-used the aluminum crush washer with no leakage issues. Great job Chris. !
boxsterfan |
Aug 21 2014, 07:10 PM
Any more people put in Chris's relief valve?
How are your oil temps? |
mapguy |
Aug 21 2014, 09:59 PM
Freelance Generalist Group: Members Posts: 90 Joined: 31-January 14 From: Inland Empire, CA Member No.: 16,945 Region Association: Southern California |
majkos |
Aug 22 2014, 08:09 AM
so far, it's been an interesting experience for me to observe.
I notice a few different things. Now I've done plenty of oil changes in a 914, since 1985. Green Machine (IMG:style_emoticons/default/first.gif) My first and still own, 914. Install EZ, thanks Chris! I checked the old oil relief SS plug, It has nasty scoured scratches on it. Hmmmmmm. Now I add oil. Put in what I thought was correct amount, I've almost a quart over?? well I'm excited to get the engine running, I can drain it later. Start her up 70-73 lbs of oil pressure. Normal. I let her run for an hour, checking everything, (Beauty is up on jacks) Temp. finally gets near 180. Good enough for me! And oil pressure is at 40 Lbs! at 1200 RPM idle. Is this ok?, I'm happy with it. Now the weird part, I go drain some oil to get it down to ,what I thought was the proper level, being under the 914, guessamating about a half quart. check oil level, no change. Dang, so I say myself, drain a lot and you can always put it back. No prob. drain about a quart and some. Oil level perfect, I have been adding an extra 1/2 qt. So I go about so with fresh drain, what I thought was fresh oil, It was BLACK! (IMG:style_emoticons/default/WTF.gif) I go to strain it thru paper towel (took FOREVER) nothing, Well I didn't reuse the oil, but I think what Beauty has been suffering thru, was the plug was stuck in cold position, sorta closed off the cooler, allowing the soots of hot burnt oil build up in the cooler, as less flow, easy deposit? I'm not complaining, I cannot wait to get it on the road for Road test temp.check. But I'm very busy with work,up till end of year. |
majkos |
Aug 22 2014, 09:12 AM
majkos |
Aug 22 2014, 09:16 AM
Lo-Fi Version | Time is now: 8th May 2024 - 08:33 AM |
