FS_Line bored 1.7L Cases w/ 2.0 crankshafts |
Jesco Reient |
May 31 2014, 09:56 PM
Member Group: Members Posts: 135 Joined: 18-July 12 From: Western Washington Member No.: 14,690 Region Association: Pacific Northwest |
I have to offer for sale two separate 1.7L cases that I have line bored. I have cut the cylinder spigots to clean them up. The oil plugs have been removed and tapped for pipe plugs, (I have aluminum AN Galley plugs available for an additional charge) The price also includes a new set of +0.50MM Mahle main bearings for the case/crank combination offered as well.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1013.photobucket.com-14690-1401594996.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1013.photobucket.com-14690-1401594996.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1013.photobucket.com-14690-1401594996.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1013.photobucket.com-14690-1401594997.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1013.photobucket.com-14690-1401594997.5.jpg) The first case and crankshaft are +0.50MM on the main Bores, with a 0.010/0.010 crankshaft and bearings. The second case and crankshaft are +0.50MM on the main Bores, with a 0.020/0.020 crankshaft and bearings. They are offered at 850.00 plus shipping each. Detailed pictures of the bearing surfaces are available upon request. Detailed sheets of the final measurements are available also. For those interested in purchasing one of these cases. You can PM me at this website, or send me an e-mail at BellCobraIV@AOL.com |
HAM Inc |
Jun 11 2014, 03:24 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Damn nice looking work John! Once word of your case work gets out there I suspect you'll end up with enough to keep quite busy.
Having done plenty of case work myself I can attest to how precise the tooling and practices need to be to end up with quality work. I quit offering case work to the public a couple of years ago as did Raby because it just takes so much time away from our primary business. Glad to see that someone has made a serious effort to fill the void. These old cases need more attention now than ever. |
Jesco Reient |
Jun 11 2014, 03:47 PM
Damn nice looking work John! Once word of your case work gets out there I suspect you'll end up with enough to keep quite busy. Having done plenty of case work myself I can attest to how precise the tooling and practices need to be to end up with quality work. I quit offering case work to the public a couple of years ago as did Raby because it just takes so much time away from our primary business. Glad to see that someone has made a serious effort to fill the void. These old cases need more attention now than ever. Len, Thank You for the kind words, I do try to treat each operation the same way I treated the engines I built that lived their lives off the ground. I treat them like the owners lives depended on them functioning correctly. You and Raby leaving the case work behind is why I decided to step in. John |
Lo-Fi Version | Time is now: 14th May 2024 - 11:19 PM |
