Ideas for non-stock parts that work really well. |
ThePaintedMan |
Jun 5 2014, 07:58 AM
Last weekend I finally got around to installing a new ground strap on the transmission since the car has always turned over pretty slow since I've owned it. I purchased a Taylor Racing ground strap from Summit Racing for $9 (along with my usual racing goodies order). WOW! What a difference. You'd think it was a high-torque starter now. The quality of these are really nice and it's a little longer than the stock strap, which I like. Gives you a little more room when dropping the motor before you remember you need to disconnect it (IMG:style_emoticons/default/smile.gif)
http://www.summitracing.com/parts/tay-20308/overview/ Also, I ordered some 3/8 in Taylor Fire Sleeve to go over the 5/16 30r9 fuel lines I have running to the carbs. In the case of a fire, I want as little chance of fuel igniting as possible. I really like this stuff - it's flexible with a nice fiberglass inner liner. I should have ordered 5/8 ID sleeve though as the 3/8 is still a really tight fit on 5/16 hose. May not be the best decision for a daily driver where you won't check the condition of fuel lines as often, but for racing it seemed like a good idea. http://www.summitracing.com/parts/tay-2511/overview/ |
76-914 |
Jun 5 2014, 08:16 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Fire sleeve is more effective if not tight fitting. Did you seal the ends. On AC engines I cinch up the end with safety wire to seal. Also, you need to think of it as a funnel. If you do have a leak where will it go with the fire sleeve installed. Hopefully not onto a hot surface. (IMG:style_emoticons/default/idea.gif)
Jun 5 2014, 10:04 AM
Custom Member Group: Members Posts: 24,580 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Cup holders....
Lo-Fi Version | Time is now: 24th May 2024 - 12:54 AM |
