Which fuel pressure regulator?, for running Weber 44 IDF's |
Aaron Cox |
Jan 17 2005, 01:46 PM
you are anal too! (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) david..thanks again for the pics you took for me, it apears we have alot of the same stuff dizzy,cdi, wires etc..... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Jan 17 2005, 06:45 PM
Custom Member Group: Members Posts: 24,570 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I strongly agree that you should not put the fuel pressure guage in the car!!!
Dont run a live pressurized fuel line into the passenger compartment. You will set the pressure and forget it, no need for the guage to be perminant. I use a race filter that can be cleaned at the track...for a long time I used he VW ones, but it was messy to replace in a hurry. I now have fuel shut offs on both sides of the filter. The filter is a stone type that filters to the same degree as the vw ones, so it works for me. Simply unscrew it and wash it with carb cleaner and then put it back in, turn on the fuel and off i go. I think I got it from Summit. Rich |
URY914 |
Jan 17 2005, 08:40 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,286 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) |
dlee1967 |
Jan 17 2005, 09:24 PM
V8Lurker Group: Members Posts: 540 Joined: 20-February 03 From: Splendora, TX Member No.: 327 Region Association: None |
Just my 2 cents, but the rotary style fuel pressure regulator that is sold at Bug shops (Bugpack or EMPI bubble pack) and also at Auto Zone (with plastic fittings) is junk. I've had two of them fail in short order. I did replace the plastic fittings with brass units for safety. How do they fail? They don't flow fuel. Their pressure gets lower and lower until no fuel passes. The autopsy revealed no internal damage, but will not allow flow. I have gone to no regulator on my V8 cars and I run two Facets in parallel so I have a backup. The needle and seats can handle the pressure of the Facet.
If your needle and seats cannot handle the Facet pressure and you must run a regulator, I suggest a Holley unit with a good quality gauge mounted away from heat in the engine compartment. My experience with the Holley units has been good on other projects (Lotus 7, Mini GT5 car and Datsun 510)and I have yet to have one fail. Why did I buy the rotary style........I had a cheap streak......It cost me in the long run. David Lee |
Lo-Fi Version | Time is now: 1st May 2024 - 11:01 AM |
