D-jet FI Part, Unknown to me |
Rhodes71/914 |
Jan 19 2005, 11:23 AM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
OK Jeff I'll repeat after you...
it's a rev limiter it's a rev limiter it's a rev limiter Thanks for clearing that up. |
RustyWa |
Jan 19 2005, 01:51 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
I've got one, but have a questions on them. Are they dependant on certain ECU's? Can you have say, a '74 ECU and then get this device and the harness with the SL wiring...will it still work?
Just curious. |
bondo |
Jan 19 2005, 02:04 PM
The decel valve doesn't do a thing to the mixture. All it does is add a controlled vacuum leak (kinda like the AAR does) when you let off the gas. It brings the RPMs down slower than would happen without it. Most people don't like this and remove it. It can calso cause funny things if it fails. |
JeffBowlsby |
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I wouldnt frankenstein these parts Rusty...its not that easy. So in a word, No. Not only are the harnesses wired a little differently, you would also need the 75-76 fuel injectors and TTS...and I bet that the 75-76 ECU is internally different to accomodate this SL. Attached image(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 07:13 PM |
