So long BUB's, good riddance, Hello little titties, and a nice 914 Rubber product |
Porschef |
Jun 17 2014, 06:45 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
We'll after over two years of these sitting in the garage (along with a myriad of other crap) I finally had accumulated what I needed to backdate. I bought these at Hershey in 2012, they were in very good shape and the tops were perfect. So l started the week before last and just dug in. I used some of Ken Steele's tutorial which worked out ok, but I found a couple other tricks that made the job go smoother.
For the front, which I did first, I found it best to leave on the valance, as it not only supports the bumper but dictates it's location. However, that thin BUB support rail has to go first; I used a dremel with a thin cutoff disc. I went through 5 or 6 but BFD (as long as we're using acronyms here). It allowed for a very smooth, fine cut. I also removed whatever flanges necessary by starting a shallow pilot hole, and then reaming the sucker out with a 1/2" bit. Worked fine. Since I don't have any friggin clue how to reduce my pic size, see ya next post |
Porschef |
Jun 17 2014, 07:23 PM
Once the bumper was removed ,I installed the factory valance, and placed Mark's LE replica spoiler into position, scribed the mounting holes from the back, and drilled it out. Very nice product, fit perfectly and looks darn good if'n you ask me.
Ok, I had already installed the horns and fogs... Used Rivnuts to do so. They are easy to install and worked great, I just centered the hole on the little flat and drilled away.., |
Lo-Fi Version | Time is now: 11th May 2024 - 06:10 AM |
