Has anyone in the US done this swing arm mod? |
Downerman |
Jun 22 2014, 10:00 AM
Member Group: Members Posts: 168 Joined: 23-April 09 From: Monterey County, California Member No.: 10,296 Region Association: None |
This was done by a gentlemen in Finland and posted here a couple of months ago. I find myself in a bit of a pickle as I read here that many guys had used the 944 Fuchs front the front (7" because 8" were on the back of 944's)) and had them on standard 914 (5 lugs of course) with no rub issues. So I bought them, restored them and mounted some pilot's (205/55/ZR16)'s to be exact. Ok, dumb me...I admit. Well, on the rear, I'm about 1" off and no-where to go and this solution looks awesome. Was wondering if there was any mods to the axles as well (I'm running turbo axles and CV's) as this is a renegade. ANYONE done this here in the states? Anyone capable or would want to take this on? Welding for me is marginal at best and to keep it aligned right has me worried. Thinking a machine shop (a professional) would be the best.
Dave Attached image(s) |
sixnotfour |
Jun 22 2014, 02:10 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I did these, used bus IRS axles,,,way to much work (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/beer.gif)
the ones you show , I doubt you can use handbrake calipers.. Attached image(s) |
mskala |
Jun 22 2014, 05:16 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Unclear what would be acceptable to you, but also 7"x16 boxster wheels have
an offset of 40 and will allow wider tires in rear. You may even need a 5mm spacer. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:54 PM |
