Has anyone in the US done this swing arm mod? |
Downerman |
Jun 22 2014, 10:00 AM
Member Group: Members Posts: 168 Joined: 23-April 09 From: Monterey County, California Member No.: 10,296 Region Association: None |
This was done by a gentlemen in Finland and posted here a couple of months ago. I find myself in a bit of a pickle as I read here that many guys had used the 944 Fuchs front the front (7" because 8" were on the back of 944's)) and had them on standard 914 (5 lugs of course) with no rub issues. So I bought them, restored them and mounted some pilot's (205/55/ZR16)'s to be exact. Ok, dumb me...I admit. Well, on the rear, I'm about 1" off and no-where to go and this solution looks awesome. Was wondering if there was any mods to the axles as well (I'm running turbo axles and CV's) as this is a renegade. ANYONE done this here in the states? Anyone capable or would want to take this on? Welding for me is marginal at best and to keep it aligned right has me worried. Thinking a machine shop (a professional) would be the best.
Dave Attached image(s) |
mskala |
Jun 24 2014, 08:44 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Okay, you can do what you want and I won't fault you for that. To me,
it seems excessive _unless_ the only look you want is the 7x16 (more lip showing than 6x16). I went with 3-piece fuchs since a set of centers became available and I need the performance of wider rims with the hoosier autocross rubber. Keep in mind that the cars are not precise with the location of everything, left side and right side. When you start pushing the limits of the fender well, be prepared to have an assortment of 1/3/5mm spacers and longer wheel studs. If you are not doing high-g cornering, you can unbolt the shock and simply move the arm up and down to see where you are at. To get your 7x16 in there, everything seems like bad ideas other than the trailing arm mod. Skinny tires would be weird. Using lots of camber might get the tires past the fenders but there is a limit due to the shims. Super-stiff springs is ghetto and will destroy your handling and frame. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:37 PM |
