Has anyone in the US done this swing arm mod? |
Downerman |
Jun 24 2014, 07:11 PM
Member Group: Members Posts: 168 Joined: 23-April 09 From: Monterey County, California Member No.: 10,296 Region Association: None |
So, for the record, on my car (3.5" Bolt to Bolt, 911 brake Calipers Up front) 5 lug of course, these 7" fuchs fit very well with room to spare. For those who want to know, the first three of the serial number on these rims are 951. I have 205/55/ZR16 Pilots on them.
Here's some pics of the rims/tires on the front and some of the rears which of course is the problem at this point. The rears will be in shape in a couple of months. I'm on the list. Dave |
mskala |
Jun 24 2014, 08:44 PM
Okay, you can do what you want and I won't fault you for that. To me,
it seems excessive _unless_ the only look you want is the 7x16 (more lip showing than 6x16). I went with 3-piece fuchs since a set of centers became available and I need the performance of wider rims with the hoosier autocross rubber. Keep in mind that the cars are not precise with the location of everything, left side and right side. When you start pushing the limits of the fender well, be prepared to have an assortment of 1/3/5mm spacers and longer wheel studs. If you are not doing high-g cornering, you can unbolt the shock and simply move the arm up and down to see where you are at. To get your 7x16 in there, everything seems like bad ideas other than the trailing arm mod. Skinny tires would be weird. Using lots of camber might get the tires past the fenders but there is a limit due to the shims. Super-stiff springs is ghetto and will destroy your handling and frame. |
scraperhand |
Jun 25 2014, 02:35 PM
Newbie Group: Members Posts: 23 Joined: 20-July 08 From: temecula,ca Member No.: 9,325 Region Association: Southern California |
Lo-Fi Version | Time is now: 1st May 2024 - 02:24 PM |
