> 2014 Parade Tech Quiz, 914 section, plus answers later in thread
Dave_Darling
post Jun 22 2014, 10:21 PM
914 Idiot
Here are the questions from the 914 section of the 2014 Parade tech quiz. Several of the questions appear to have been written by "real" 914 folks; see for instance Q 53 answer a. (IMG:style_emoticons/default/smile.gif)
There are a few answers that are debatable, according to your point of view as well.
The questions I got wrong were: 55, 67, 69. I actually got 67 right, but the official answer was wrong. (That question was successfully protested and thrown out.)
51) The 914-4 is known internally (at the VW factory) as the
a) peoples’ car;
b) Karmann;
c) VW-Porsche;
d) VW Type 47.
52) Pop-up headlights were used on the 914
a) in order to comply with U.S. lighting-height law;
b) to give sleeker appearance when not in use;
c) as an attempt to keep them cleaner;
d) to develop the concept for the future 924.
53) What is the approximate fuel pressure at the injectors of the D-Jetronic system?
a) Enough for a leak
b) 75 psi
c) 10 psi
d) 30 psi
54) Both the 914-4 and 914-6 used a hand throttle.
a) True
b) False
55) A 914-6 was used as a pace car for the 1971 Daytona 500.
a) True
b) False
56) For the 1974 model year American market the base engine was a 1.8 liter with
a) D-Jetronic fuel injection;
b) L-Jetronic fuel injection;
c) K-Jetronic fuel injection;
d) Motronic fuel injection.
57) The 914 used the same 901 gear box as the 911 but turned end for end. Because of the __________.
a) the ring gear had to be mounted opposite of the 911 location.
b) it required a reverse rotation throwout bearing
c) all the gears had to be flipped end for end
d) the engine rotation was reversed
58) The front suspension on the 914 is
a) unequal length A arm;
b) coil spring concentric with shock;
c) torsion bars with McPherson struts and lower wishbones.
d) torsion bar concentric with shock;
59) The 914 1.8 liter camshaft is driven by _________
a) timing chain
b) toothed belt
c) gears
d) pure luck
60) The 1.7 and 1.8 liter engines do not share the same crankshaft.
a) True
b) False
61) The windshield wiper switch on a 1970 914-4 was located
a) The switch was made by Lucas and never worked, so it doesn’t matter where it was.
b) on the steering column.
c) on the dash
d) on the center console
62) The brake lights are activated by a hydraulic switch.
a) True
b) False
63) A shortcoming of the early 914’s was the shift linkage. The improved version came in 1973.
a) True
b) False
64) What tool is needed to remove the tail light lenses on the 914?
a) Fingers
b) Phillips screwdriver
c) Straight tip screwdriver
d) 10mm wrench
65) The engine of the 914/6 was the same as used in the 1970 911T.
a) True
b) False
66) All 914 bodies were built by
a) Reutter
b) Porsche
c) Karmann
d) VW
67) The production 914-4 and 914-6 cars for the U.S. market had the “Porsche” crest on the hood.
a) True
b) False
68) In 1973 the method for wheel centering was changed from _______.
a) bolt centric to hub centric
b) hub centric to bolt centric
c) orbitally to closed cone method
d) variable to definite
69) The firing order of the 914/6 engine is ______.
a) 18436572
b) 146325
c) 164235
d) 162435
70) The hoses on 1973 914 2.0 fuel injection unit are color coded. The brown hoses are related to the ____________.
a) deceleration valve
b) windscreen washer
c) distributor
d) EGR valve
71) The vapor lock problem on 914-4’s was alleviated when Porsche moved the fuel pump to the front of the car.
a) True
b) False
72) The 914-6 option package M471 included ______________.
a) flared fenders.
b) flared rocker panels.
c) flared front valance.
d) all of the above
73) For 1970 and 71 leather trim was only available on six-cylinder models.
a) True
b) False
74) The problems with the shaft and bushings which support the brake and clutch pedal assembly could cause _______________.
a) dragging brakes
b) overheated brakes
c) inconsistent pedal height
d) all of the above
75) On a 914 1.8 there are two electric boxes attached to the underside of the battery tray. One is the J40 double relay and the other is a resistor package that provides reduced voltage from the battery to the __________.
a) interior light
b) tachometer
c) brake lights
d) fuel injectors
Dave_Darling   2014 Parade Tech Quiz, 914 section   Jun 22 2014, 10:21 PM
ConeDodger   Pure luck crankshaft drive... What a novel idea th...   Jun 22 2014, 11:51 PM
barefoot   where are answers posted ??   Jun 23 2014, 06:55 AM
Dave_Darling   where are answers posted ?? They aren't. ...   Jun 23 2014, 11:05 AM
GeorgeRud   They actually managed to have some printing/collat...   Jun 23 2014, 08:34 AM
SLITS   d,a,d,b,a,b,d,c,c,b,c,b,a,a,a,c,b,a,d,a,a,d,a,c,d....   Jun 23 2014, 11:26 AM
Dave_Darling   d,a,d,b,a,b,a,c,c,b,c,b,a,a,b,c,b,a,d,a,a,d,a,d,d ...   Jun 24 2014, 11:44 AM
SLITS   d,a,d,b,a,b,a,c,c,b,c,b,a,a,b,c,b,a,d,a,a,d,a,d,d...   Jun 24 2014, 02:43 PM
Jeff Bowlsby   Those are tough questions Dave...Congrats to you...   Jun 23 2014, 01:19 PM
Dave_Darling   Answers here: 1) The 91...   Jun 24 2014, 11:41 AM
Cap'n Krusty   I coulda been the winner! The Cap'n   Jun 24 2014, 02:19 PM
Dave_Darling   It's a lot easier here than sitting in a room ...   Jun 24 2014, 02:34 PM
The Cabinetmaker   I only missed #69 cause I had no idea. Never worke...   Jun 24 2014, 02:56 PM
Jeff Bowlsby   I think we should start a thread and generate our ...   Jun 24 2014, 03:03 PM
ConeDodger   Class: Q06M Region 914 1 107 5 0592A Darling David...   Jun 24 2014, 03:40 PM
Dave_Darling   So, I didn't see an overall winner. Were the t...   Jun 24 2014, 05:16 PM
Krieger   E. All of the above.   Jun 24 2014, 04:00 PM
Krieger   Good job Dave :first:   Jun 24 2014, 04:01 PM
dlkawashima   I guess I don't understand how the scoring goe...   Jun 24 2014, 06:53 PM
theleschyouknow   I guess I don't understand how the scoring go...   Jun 24 2014, 07:09 PM
theleschyouknow   I guess I don't understand how the scoring g...   Jun 24 2014, 07:13 PM
Jamie   [quote name='theleschyouknow' post='2053991' date...   Jun 24 2014, 08:56 PM
Dave_Darling   I guess I don't understand how the scoring go...   Jun 24 2014, 09:35 PM
theleschyouknow   I guess I don't understand how the scoring g...   Jun 24 2014, 11:04 PM
Manny Alban   Yup, I'm a long time 914 owner (73 2.0) and de...   Jun 24 2014, 09:22 PM
theleschyouknow   Yup, I'm a long time 914 owner (73 2.0) and d...   Jun 24 2014, 10:56 PM
Dave_Darling   Oops. Yeah, that's 137 for my overall total. ...   Jun 25 2014, 08:44 AM
Tom   Dave, Question about #61, 1970 914 windshield w...   Jun 25 2014, 11:59 AM
Cap'n Krusty   The "brown" hoses in question 70 were ac...   Jun 27 2014, 09:20 AM
Dave_Darling   IIRC, there were brown hoses and there were red ho...   Jun 27 2014, 12:29 PM
Cap'n Krusty   IIRC, and it's been a while, they arrived at t...   Jun 27 2014, 12:48 PM
- Lo-Fi Version Time is now: 2nd May 2026 - 11:02 AM
