My 3.2 Conversion |
My 3.2 Conversion |
Clemson |
Jun 24 2014, 05:15 PM
1974 914 1.8 1987 911 cab 2002 Audi S6 avant Group: Members Posts: 52 Joined: 27-April 14 From: Banner Elk, NC Member No.: 17,288 Region Association: South East States |
dlee6204 |
Jun 24 2014, 05:40 PM
Anyone need a 1.8 with webers? Maybe... (IMG:style_emoticons/default/idea.gif) what are the details on it? |
Clemson |
Jun 24 2014, 06:41 PM
(IMG:style_emoticons/default/popcorn[1].gif) Anyone need a 1.8 with webers? Maybe... (IMG:style_emoticons/default/idea.gif) what are the details on it? I really don't know the history. I bought the car back in May. Ran fine from Columbia SC to Banner Elk, NC then down to the shop near Charlotte plus a few drives in the mountains. |
Clemson |
Jul 1 2014, 07:20 AM
Attached thumbnail(s) |
Steve |
Jul 1 2014, 11:19 AM
914 Guru Group: Members Posts: 5,565 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Take Air Flow Meter off. Otherwise it will hit the rear trunk. You will need to angle it towards the front to fit. Check my blog for pictures.
Clemson |
Jul 1 2014, 12:13 PM
swooshdave |
Jul 1 2014, 01:27 PM
Member Group: Members Posts: 184 Joined: 11-June 14 From: Portland Member No.: 17,475 Region Association: Pacific Northwest |
Elliot Cannon |
Jul 1 2014, 01:32 PM
Click on his name above the avatar to find a blog. |
patssle |
Jul 1 2014, 03:08 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Your oil cooler needs to be modified with a 90 degree fitting welded on. Rich Johnson does it - I used him. See: http://www.914world.com/bbs2/index.php?showtopic=4319
Also isn't the PMS motor mount great? So glad I paid the little extra for it instead of the normal bulkhead welded mounts. |
Steve |
Jul 1 2014, 08:03 PM
For me it was easier to remove the airflow meter and then modify it to fit after the motor was in the car. Otherwise the AFM will hit the engine lid latch and prevent you from installing the motor. I actually just put the motor back in the car a month ago. I am using extenders from Pep boys and a MSDS Cone filter and his adapter. You can also click my name and then check my blog to see pictures of how i used the stock air cleaner. Here are some links to a couple of pictures in my blog.
http://www.914world.com/bbs2/index.php?aut...ach&id=1704 http://www.914world.com/bbs2/index.php?aut...ach&id=1706 |
Clemson |
Jul 2 2014, 05:49 AM
For me it was easier to remove the airflow meter and then modify it to fit after the motor was in the car. Otherwise the AFM will hit the engine lid latch and prevent you from installing the motor. I actually just put the motor back in the car a month ago. I am using extenders from Pep boys and a MSDS Cone filter and his adapter. You can also click my name and then check my blog to see pictures of how i used the stock air cleaner. Here are some links to a couple of pictures in my blog. http://www.914world.com/bbs2/index.php?aut...ach&id=1704 http://www.914world.com/bbs2/index.php?aut...ach&id=1706 good info, thank you |
dcecc1968 |
Jul 2 2014, 05:56 AM
Member Group: Members Posts: 251 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
Hey, I recognize that shop. John does good work.
Clemson |
Jul 2 2014, 04:56 PM
patssle |
Jul 2 2014, 07:25 PM
Steve |
Jul 7 2014, 04:41 PM
Clemson |
Aug 14 2014, 05:52 PM
Its been awhile since my last update. Here are some current pics. John found a little rust (there is no such thing as a rust free 914) when his shop was removing the old 4 cly. mounts. We decided to plate the area and add a chassis stiffening kit.
Its been going a little slow but the transaxle has been rebuilt including a billet intermediate plate. Its all bolted up ready to install once the engine compartment gets painted. I am going down Friday to see it in person and hopefully see the engine / trans installed. Can't wait to drive it! Attached thumbnail(s) |
Clemson |
Aug 15 2014, 09:40 AM
The engine compartment finally is painted!
Clemson |
Aug 18 2014, 03:06 PM
Now that the metal work has been finished up, the engine and transaxle was installed today. Notice the billet pieces on the transaxle, hopefully the 901 will handle the power of the 3.2.
MoveQik |
Aug 18 2014, 04:21 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Now that the metal work has been finished up, the engine and transaxle was installed today. Notice the billet pieces on the transaxle, hopefully the 901 will handle the power of the 3.2. I've been running my 3.2 with a 901 since 2006. Guys run 3.6's. You'll be fine unless you really plan on beating on the car. Cool conversion! |
naro914 |
Aug 18 2014, 04:32 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
901 will be fine with a 3.2...that's what's in both Huey and Papa Smurf.
Hey, I stood under your car earlier today just as they were putting the exhaust on. Nice car...you ARE bringing it to Okteenerfest...right? John said you're going... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 19th April 2024 - 05:00 AM |
