Track car alignment, new content |
Jetsetsurfshop |
Jun 27 2014, 06:34 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Hey Paddock people,
With a dedicated track car, whats your alignment setting? My dad and I set ours up with what we thought is right. After about 10 track days I removed the RA1's and noticed the wear pattern isn't even. I can't remember if the front or the rears were more uneven. I flipped them around on the rims to get them to last longer. Any help, as always, is much appreciated. (IMG:style_emoticons/default/biggrin.gif) Shane |
ThePaintedMan |
Apr 20 2017, 11:45 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Yup, use crayons where the triangles are to set a new reference mark.
I think 2mm out is probably overkill for your car, given the way Bob's is setup. But 1/8th toe-in is a lot, even for a street car. I'm pretty sure mine is setup at zero on the front and 1/16th in on the back. You'll gain toe slightly at speed anyways, given the tolerances on most suspensions, especially ours, so the most you'd probably ever need is 1/16th out on the front. Also - the more caster you run, the more camber you'll gain with the turning of the wheels as well. Most of us I believe run the caster as far back as it'll go, and then you'll likely have all you need, and can get rid of some of the static camber. |
Lo-Fi Version | Time is now: 21st May 2024 - 04:09 AM |
