Track car alignment, new content |
Jetsetsurfshop |
Jun 27 2014, 06:34 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Hey Paddock people,
With a dedicated track car, whats your alignment setting? My dad and I set ours up with what we thought is right. After about 10 track days I removed the RA1's and noticed the wear pattern isn't even. I can't remember if the front or the rears were more uneven. I flipped them around on the rims to get them to last longer. Any help, as always, is much appreciated. (IMG:style_emoticons/default/biggrin.gif) Shane |
falcor75 |
Apr 27 2017, 07:10 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Thanks for the tip George.
Just back from the alignment shop and I cant seem to get toe in on the left rear wheel. Right side is at 2 degrees toe in but the right side is at 2 degrees toe out despite that I have elongated the holes in the outer trailing arm bracket as much as possible. I did check the mounting hole dimensions according to the underpan picture here on the World and it seemed spot on. Starting to suspect I have a bent trailing arm... Does anyone have good dimensons to check it for straightness? |
mepstein |
Apr 27 2017, 09:00 AM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Thanks for the tip George. Just back from the alignment shop and I cant seem to get toe in on the left rear wheel. Right side is at 2 degrees toe in but the right side is at 2 degrees toe out despite that I have elongated the holes in the outer trailing arm bracket as much as possible. I did check the mounting hole dimensions according to the underpan picture here on the World and it seemed spot on. Starting to suspect I have a bent trailing arm... Does anyone have good dimensons to check it for straightness? If it turns out you need a new one, I'll send you one for the cost of shipping. |
Lo-Fi Version | Time is now: 21st May 2024 - 10:29 AM |
