Track car alignment, new content |
Jetsetsurfshop |
Jun 27 2014, 06:34 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Hey Paddock people,
With a dedicated track car, whats your alignment setting? My dad and I set ours up with what we thought is right. After about 10 track days I removed the RA1's and noticed the wear pattern isn't even. I can't remember if the front or the rears were more uneven. I flipped them around on the rims to get them to last longer. Any help, as always, is much appreciated. (IMG:style_emoticons/default/biggrin.gif) Shane |
falcor75 |
Apr 27 2017, 07:10 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Thanks for the tip George.
Just back from the alignment shop and I cant seem to get toe in on the left rear wheel. Right side is at 2 degrees toe in but the right side is at 2 degrees toe out despite that I have elongated the holes in the outer trailing arm bracket as much as possible. I did check the mounting hole dimensions according to the underpan picture here on the World and it seemed spot on. Starting to suspect I have a bent trailing arm... Does anyone have good dimensons to check it for straightness? |
naro914 |
Apr 27 2017, 11:48 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
Thanks for the tip George. Just back from the alignment shop and I cant seem to get toe in on the left rear wheel. Right side is at 2 degrees toe in but the right side is at 2 degrees toe out despite that I have elongated the holes in the outer trailing arm bracket as much as possible. I did check the mounting hole dimensions according to the underpan picture here on the World and it seemed spot on. Starting to suspect I have a bent trailing arm... Does anyone have good dimensons to check it for straightness? Does the console (the 'mount' where the elongated holes are) hit up against the chassis? Is that's what's stopping you from getting more toe in? That's what was wrong with ours, we had to grind down on the console until we could move it enough...both sides. Did it at the track. |
Lo-Fi Version | Time is now: 21st May 2024 - 03:30 AM |
