Track car alignment, new content |
Jetsetsurfshop |
Jun 27 2014, 06:34 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Hey Paddock people,
With a dedicated track car, whats your alignment setting? My dad and I set ours up with what we thought is right. After about 10 track days I removed the RA1's and noticed the wear pattern isn't even. I can't remember if the front or the rears were more uneven. I flipped them around on the rims to get them to last longer. Any help, as always, is much appreciated. (IMG:style_emoticons/default/biggrin.gif) Shane |
falcor75 |
Apr 27 2017, 12:26 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I've got Chris's outer brackets on the car and I've filed the mouthing holes up around 5 mm, might get another mm in there but then the round part will start to hit the body. Then again that is solvable by reducing the camber to make the mount sit lower. But then I start running into interference between my 195/55 tires and the inner lip of the fender.
I'll borrow a fender roller this weekend and see if I can gain more clearance.... |
ChrisFoley |
Apr 27 2017, 02:08 PM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I've got Chris's outer brackets on the car and I've filed the mouthing holes up around 5 mm, might get another mm in there but then the round part will start to hit the body. Then again that is solvable by reducing the camber to make the mount sit lower. But then I start running into interference between my 195/55 tires and the inner lip of the fender. I'll borrow a fender roller this weekend and see if I can gain more clearance.... Is there a GT stiffening kit on the chassis? If so, the piece which goes on the back side of the outer console will cause the same trouble you're experiencing. I just completed an alignment on a 95% street/5% autocross car. We ended up with 0.5 deg front/0.6 deg rear, and about 1mm toe in all 4 corners. Stock front A/S bar, although I'm recommending to the owner that he purchase a 19mm adjustable bar. 205/55 tires on Fuchs alloys and no issues with fender clearance. I went through my test curves on a local road, comfortably - as fast as I dare drive a customer car through there. |
Lo-Fi Version | Time is now: 21st May 2024 - 07:04 PM |
