Track car alignment, new content |
Jetsetsurfshop |
Jun 27 2014, 06:34 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Hey Paddock people,
With a dedicated track car, whats your alignment setting? My dad and I set ours up with what we thought is right. After about 10 track days I removed the RA1's and noticed the wear pattern isn't even. I can't remember if the front or the rears were more uneven. I flipped them around on the rims to get them to last longer. Any help, as always, is much appreciated. (IMG:style_emoticons/default/biggrin.gif) Shane |
falcor75 |
Apr 27 2017, 10:16 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Yes I have your full stiffening kit with the rod braces on the car.
ChrisFoley |
Apr 28 2017, 04:39 AM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Yes I have your full stiffening kit with the rod braces on the car. My kit doesn't have the surface mounted plates that the GT kit has so that's not part of your problem. It may be that you have a bent trailing arm. The angle between pivot and axle in the horizontal plane is 12.5 degrees IIRC. There is also a built in camber of 1.5 degrees. There are no other measurements that I know of, although I think I've seen a picture of a go-no go fixture used to verify a trailing arm. |
Lo-Fi Version | Time is now: 21st May 2024 - 02:56 PM |
