-6 Throttle Cable Connection, Not using the transmission pivot |
patssle |
Jun 29 2014, 10:44 AM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
The /4 cable is more than long enough not to need the extra hardware to pivot on the transmission and save some money. Just need to fabricate a bracket and mount it off one of the couple spots available.
My /4 cable does not have a threaded end to attach a ball socket. Has anybody else worked with this and somehow either put a ball socket on a non-threaded cable or used something on the bar linkage that allows for cable movement? |
GeorgeRud |
Jun 29 2014, 11:31 AM
Perhaps you could braze a ball end onto the end of the cable or try to drill, tap, and install a small Allen head setscrew to hold the connector onto the cable. Then you'd have to have a bracket that can adjust the hold down at the cable shroud.
When it's all said and done, I wonder if mimicking the factory setup may not be easier and cheaper in the long run. |
Jeff Hail |
Jun 29 2014, 11:54 AM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
The bell crank on the trans and rod method seems to work better in my opinion versus the direct cable connection on the carbs or FI. The direction of pull is correct. Ratio to lever on pedal cluster is correct. Tension on the cable is less. Operation is smoother. The only thing depending on which setup you are using is the correct bell crank. 914-6, 911 Carbs, 911FI, 911 mechanical spritzen all used different bell cranks.
SirAndy |
Jun 29 2014, 12:20 PM
Resident German Group: Admin Posts: 41,609 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I don't use the bell-crank on my /6 but i won't be of much help here since i simply bought the PMS cable that is already setup to do what you're trying to do.
8 years and no problems with the wrap around cable at all ... (IMG:style_emoticons/default/smile.gif) |
Jeffs9146 |
Jun 29 2014, 01:20 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
You could thread the end!
SLITS |
Jun 29 2014, 03:47 PM
End is too small to thread as I remember.
1.) Weld the ball end to the cable (I've done this twice). Still holding after 4 years on current car. 2.) Call Terry Cable and have them make you one that is threaded on the end. I carry one as a spare and it cost me about $60.00. |
patssle |
Aug 31 2014, 05:30 PM
Just to share my solution...utilizing the original CIS throttle plate with an angle piece of steel mounted on top. Brazed the ball to the end of the cable.
Attached thumbnail(s) |
McMark |
Aug 31 2014, 09:18 PM
That'll work. (IMG:style_emoticons/default/thumb3d.gif)
eyesright |
Aug 31 2014, 10:03 PM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
After assembling all the needed pieces at considerable cost and Dan's Way posted on my garage wall, I'd already come to the conclusion that Ferry and his summer intern nephews started with the 911 arrangement and just never looked past reversing the system, instead of just simplifying things...incredible! How could they have missed it. (IMG:style_emoticons/default/agree.gif) Since I have all the parts, I may use the factory setup, but the next one will look like yours. |
IronHillRestorations |
Sep 1 2014, 06:44 AM
I. I. R. C. Group: Members Posts: 6,715 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
In one of the old Upfixin De Porsche someone wrote an article about using a 914-6 cable and they made some cable brackets for the side of the trans and connected directly to the 6 throttle linkage, which seemed like a good solution.
JStroud |
Sep 1 2014, 09:47 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Lo-Fi Version | Time is now: 2nd May 2024 - 02:19 PM |
