-6 Throttle Cable Connection, Not using the transmission pivot |
patssle |
Jun 29 2014, 10:44 AM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
The /4 cable is more than long enough not to need the extra hardware to pivot on the transmission and save some money. Just need to fabricate a bracket and mount it off one of the couple spots available.
My /4 cable does not have a threaded end to attach a ball socket. Has anybody else worked with this and somehow either put a ball socket on a non-threaded cable or used something on the bar linkage that allows for cable movement? |
SirAndy |
Jun 29 2014, 12:20 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I don't use the bell-crank on my /6 but i won't be of much help here since i simply bought the PMS cable that is already setup to do what you're trying to do.
8 years and no problems with the wrap around cable at all ... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 05:42 AM |
