-6 Throttle Cable Connection, Not using the transmission pivot |
patssle |
Jun 29 2014, 10:44 AM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
The /4 cable is more than long enough not to need the extra hardware to pivot on the transmission and save some money. Just need to fabricate a bracket and mount it off one of the couple spots available.
My /4 cable does not have a threaded end to attach a ball socket. Has anybody else worked with this and somehow either put a ball socket on a non-threaded cable or used something on the bar linkage that allows for cable movement? |
patssle |
Aug 31 2014, 05:30 PM
Just to share my solution...utilizing the original CIS throttle plate with an angle piece of steel mounted on top. Brazed the ball to the end of the cable.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:36 AM |
